lower strut bolt??
Old Feb 25, 2003 | 10:15 AM
pg_thao's Avatar
Default lower strut bolt??
whats the easiest way to take the lower strut bolt of the LCA.. i've tried my impact gun but its not comming out.. should i heat it up before i take the impact gun to it?
Old Feb 27, 2003 | 09:09 AM
pg_thao's Avatar
Default Re: lower strut bolt?? (pg_thao)
to the top..
Old Feb 27, 2003 | 11:22 AM
Sunrise City Rider's Avatar
Breaker bar...Enough leverage and you can move the world...
Zee
Old Feb 27, 2003 | 12:39 PM
94CivicSi's Avatar
Default Re: lower strut bolt?? (Sunrise City Rider)
it's going to break no matter what you do. The bolt is corroded to the sleeve in the bushing.
Buy new bolts, buy some replacement bushings and then get ready to do some cutting. I put the blade of a hack saw between the the control arm and the shock, both sides, and cut all the way through the bolt. Once the shock is free of the LCA, burn the bushing out and reassemble with LOTS OF ANTI-SIEZE!!!!
Old Feb 27, 2003 | 12:48 PM
warwagon's Avatar
Default Re: lower strut bolt?? (94CivicSi)
yep, torched mine out!!!!!!!!!!!! can you put a new bushing in when the lca is on the car? kinda created a busing for mine!!
91 b20 integra
11
May 18, 2013 03:33 PM
shake_em
Dec 3, 2007 11:30 PM
komat
20
Dec 26, 2004 10:04 PM
unknown317
Jul 27, 2003 09:23 PM
arete213
Nov 12, 2001 02:16 PM
