thinking about getting lower deg thermostat
Old Feb 23, 2003 | 11:25 PM
SSBP DC2's Avatar
Default thinking about getting lower deg thermostat
are most thermostat created equal (physically?)
i'm thinking about getting a lower deg thermostat from the local autoparts. Does anyone know which application i should ask for? I'm looking to get around 160 degree or something. TIA for the help guys.
-demitri
who believes the stock GSR radiator is underated
Old Feb 24, 2003 | 07:31 AM
qtiger's Avatar
Default Re: thinking about getting lower deg thermostat (SSPB DC2)
I bought a 160 degree thermostat from the auto parts store when I did my swap, assuming that I should change it.
When I took out the Honda thermostat it became immediately obvious that the auto parts thermo was a total POS in comparison. I put the Honda one back in and returned the other.
Old Feb 24, 2003 | 09:35 AM
Padawan's Avatar
Darth ModerVader
Try Water Wetter. And just out of curiosity, what has led you to believe that you need to lower coolant temperatures?
Old Feb 24, 2003 | 10:03 AM
advanracing62's Avatar
Default Re: thinking about getting lower deg thermostat (Padawan)
I've got the Spoon thermo, fan switch, and rad cap... it takes FOREVER for my car to warm up when it's chilly. During the warmer months, it helps ALOT when combined with water wetter. Spoon parts are, as we all know, factory Honda parts slightly modified... HTH
Old Feb 25, 2003 | 03:41 PM
SSBP DC2's Avatar
Default Re: thinking about getting lower deg thermostat (advanracing62)
i just want my car to run a little cooler, it's just been on my mind lately although i know it will take a little longer to warm up. it's just one of those things on my to do list, you know. never thought about water wetter though, maybe it's time to try some. do we use it like the regular coolant? 50/50 mix or something? sorry, not my area of expertise. thanks
Old Feb 25, 2003 | 03:44 PM
mph6563's Avatar
Why do you think your engine should run cooler than its design temperature?
Old Feb 25, 2003 | 06:48 PM
Padawan's Avatar
Darth ModerVader
http://www.redlineoil.com/redlineoil/wwti.htm
Old Feb 25, 2003 | 07:50 PM
SSBP DC2's Avatar
Default Re: thinking about getting lower deg thermostat (mph6563)
i was thinking should the thermostat open at a lower degree, it will circulate at an earlier temperature hence keeping the motor at a lower operating temp.
thank you for the link
Old Feb 25, 2003 | 07:57 PM
Lsos's Avatar
I believe the hotter an internal combustion engine runs, the more efficient it is.
Old Feb 25, 2003 | 08:05 PM
SSBP DC2's Avatar
Default Re: thinking about getting lower deg thermostat (Lsos)
really? then let's do away with the cooling system
no offense intended, but could you provide me with some reading materials to back your belief? thanks
Old Feb 25, 2003 | 09:40 PM
InevitableRace's Avatar
[quote]I believe the hotter an internal combustion engine runs, the more efficient it is.[quote]
You keep thinking that Buddy.....
Old Feb 25, 2003 | 09:53 PM
deepgreengsr's Avatar
Default Re: thinking about getting lower deg thermostat (allmotrb18c1)
Old Feb 26, 2003 | 02:10 PM
SSBP DC2's Avatar
Default Re: thinking about getting lower deg thermostat (deepgreengsr)
i was recently informed that all water wetter does is add lipid bi-layer to water. could someone back this? i've read the entire water wetter article from redline and it doesn't seem so.
Old Feb 26, 2003 | 03:51 PM
Lsos's Avatar
Running an engine cooler decreases its thermal efficiency. Imagine running coolant at absolute zero. The heat in the combustion chamber would get transfered right into the coolant, and there'd be little of it left to do any work.
http://www.grapeaperacing.com/GrapeA...lingbasics.cfm
http://www.azom.com/details.asp?ArticleID=739
http://engine.firebirdv6.com/
You guys should probably do some research before assuming I'm wrong and jumping on the bandwagon of mocking me out
Old Feb 26, 2003 | 03:54 PM
tominos's Avatar
yea, you need to run at normal operating temperature for everything to work right, some sensors, don't run right until n.o.t. also, you will get the best gas mileage when at normal oper. temp. i've looked into getting a lower thermostat before but did some research first.
DDY_EGC
Nov 27, 2018 05:14 PM
daniel42
Honda Civic (2001 - 2005)
Oct 27, 2017 09:08 AM
mrfootball420
Oct 14, 2009 06:03 PM
I got a honda
19
Dec 11, 2005 05:32 PM
JDMlyfestyle
16
Jan 14, 2004 05:18 PM
