timing off by half a tooth...
Old Feb 24, 2003 | 01:52 PM
baonest1's Avatar
Default timing off by half a tooth...
my timing is off by half a tooth. when i dropped my motor in, it was perfect. the break in period must have affected it. i have adjustable cam gears. moving the gear back 2 degrees looks like a perfect fit. i was curious if that would solve my timing problem. or would i need to take the belt off and move the cam itself.
thanx
Old Feb 24, 2003 | 02:26 PM
tilt's Avatar
Default Re: timing off by half a tooth... (baonest)
Can you explain how the belt is off by 1/2 a tooth? last time I checked the belt can only be put on the gears with whole teeth.
Old Feb 24, 2003 | 02:31 PM
sgT's Avatar
sgT
thanx
lol
the breakin must have done it hahahaha
thats a good one.
what timing problem are you having?
Old Feb 24, 2003 | 02:43 PM
RAWB's Avatar
Don't just start moving things to make it "look" like it is lined up. Remove the belt and set to TDC and follow the procedure for a new timing belt installation. Be sure to check everything with a timing light when done.
Your cam gears are most likely not giving you true indexing marks. GL
Old Feb 24, 2003 | 02:57 PM
baonest1's Avatar
Default Re: timing off by half a tooth... (sgT)
DOH.. me. lemme rethink this.
[Modified by baonest, 7:01 PM 2/24/2003]
Old Feb 24, 2003 | 03:37 PM
baonest1's Avatar
when checking timing.. i have the gun on 0 degree then it is supposed to line up at the white single mark right.. and the 3 marks together are 14 deg, 16deg , 18deg .
pkdog167
Nov 10, 2009 10:29 PM
HybriDNA
Mar 29, 2003 09:14 PM
blufke
Mar 27, 2003 05:03 AM
keebler65
Mar 31, 2002 12:24 PM
