headgasket q.
Old Feb 22, 2003 | 01:20 PM
Dancing is Forbidden's Avatar
Default headgasket q.
What head gasket should I go with on a Boosted b18a, that should see at least 14psi? Thanks.
Old Mar 20, 2003 | 05:40 PM
X-Mazda 3 Racer's Avatar
Default Re: headgasket q. (EF9_SiR)
Use a stock gasket. That's what we use!!! Holds over 50 psi. boost
Old Mar 20, 2003 | 07:10 PM
intekragsr's Avatar
well depends. Are you putting it in because you need replacement or just to lower compression? If you have the money, just build the motor, but if your like me and broke, lower comp. with the headgasket.
Just call inline pro and ask them for suggestions.
Old Mar 20, 2003 | 07:18 PM
dfoxengr's Avatar
Default Re: headgasket q. (intekragsr)
YES inline pro is the BEST...
Old Mar 21, 2003 | 07:18 PM
Default Re: headgasket q. (hybridvteceg)
well it is for an LS that has 9.0 wisecos that I am building. I just want a sturdy head gasket. Thanks.
silentdaredevil2
Nov 24, 2005 12:29 PM
eh2-hb
Oct 13, 2005 10:01 PM
L5turbo415
Feb 12, 2004 09:21 PM
1.8T_EG
Sep 30, 2002 04:31 PM
S2Kpower
Sep 19, 2002 01:10 PM
