broken tps plug
Old Feb 22, 2003 | 11:43 AM
See Are X's Avatar
Default broken tps plug
my tps plug cracked off the tps sensor while putting in my motor. Along with the plug, one of the three prongs(silver thing the wire goes too) broke off also, its the top one. I believe the yellow wire is the one that goes there. What is this yellow wire?? how will it affect my idle/performance?
Old Feb 22, 2003 | 12:24 PM
eg6ajk's Avatar
Default Re: broken tps plug (See Are X)
TPS code is a major one, the car will not work very well, bogging and low performance is usually the result.
grn/blu = - (D22)
red/blk=- (D11)
yel/blu=+ (D20)
D22/D20 provide constant voltage (4.5V max) while the middle wire measures and send it to the ecu to calculate the load (WOT and what not)(TPS is a potentiometer)
Old Feb 22, 2003 | 12:34 PM
See Are X's Avatar
Default Re: broken tps plug (eg6ajk)
im gonna try and solder the wire to the prong on the sensor...is there a way I can check the connection???
Old Feb 23, 2003 | 08:20 AM
See Are X's Avatar
will any honda tps sensor work for the gsr?
BoostedSiEM1
Sep 23, 2012 02:25 PM
turbo-crx
Sep 30, 2008 10:00 AM
team_lunatics
Sep 27, 2008 04:59 PM
Morhpeous
May 30, 2004 05:33 PM
