sleeving a b18c1 to 2.0?
Old Feb 23, 2003 | 07:57 PM
Kermit EK's Avatar
Default sleeving a b18c1 to 2.0?
When sleeving a b18c1 and using a PR-3 head do you have to do anything to the head and combustion chamber? And does anyone have any pics of a sleeved block as if you were looking down the cylinders from the oil pan side? thanks!
Old Feb 23, 2003 | 08:01 PM
Kataku2K3's Avatar
Default Re: sleeving a b18c1 to 2.0? (Kermit EK)
Have it portmatched to the bore... I assume that you are goin somewhere in the neighborhood of 85mm so have the head matched to that... This pic is courtesy of sgT... Golden Eagle sleeved B18C... http://www.goldeneaglemfg.com/sleeves.htm
Old Feb 23, 2003 | 08:04 PM
TREVER's Avatar
I disagree I would use the head without porting to macth the bore. A waste of money imo.
Old Feb 23, 2003 | 08:06 PM
Kermit EK's Avatar
Default Re: sleeving a b18c1 to 2.0? (Kataku2K3)
thanks! thats Exactly what I was looking for, when you say port matched you mean open up the combustion chamber to the same size as the bore of the block wright?
Old Feb 23, 2003 | 08:44 PM
Kermit EK's Avatar
bump
Kataku2K3's Avatar
Yup!!!
Old Feb 23, 2003 | 08:54 PM
TREVER's Avatar
Let me ask you a Q, what is the benefit of port matching the combustion chamber?
Old Feb 23, 2003 | 09:00 PM
Al Bundy's Avatar
Default Re: sleeving a b18c1 to 2.0? (TREVER)
Gives you more CC's?
Old Feb 23, 2003 | 09:22 PM
boosted hybrid's Avatar
It gets rid of a potential hot spot in the combustion chamber. On my built 2.0 gsr turbo block i run a 81mm bore on the head, and 84.5mm bore on the block. For FI I wish i would have spot faced the head to 84.5mm, but i bought the head already done from portflow. For my 2.1L gsr all motor block i spot faced the 86mm bore to the head. The only advantage i can see is that you can run a higher timing curve, and gain some power in that manner. With 13:1 on pump gas, I wanted get rid of any potential detonation that could be caused by the 81mm lip around the 86mm bore.
Old Feb 23, 2003 | 09:24 PM
Default Re: sleeving a b18c1 to 2.0? (Al Bundy)
It gives you more cc's, not CC's. You dont gain any displacement, you lose compression. Think of it as making the head a "low" compression head in domesitc terms. I ordered my arias pistons with 13.5:1 compression anticipating a .4~.5:1 compression drop spot facing my head to 86mm so i could achieve a solid 12.8~13:1 compression.
Old Feb 23, 2003 | 10:40 PM
Kataku2K3's Avatar
Default Re: sleeving a b18c1 to 2.0? (boosted hybrid)
Exacty as boosted hybrid put it... Matching the bore only increases the combustion chamber volume therefore decreasing your C/R... The overall displacement of a motor if figured by the ((pie)(bore^2))(stroke)... For example an 86mm B18C with LS/CRV crank... ((pie)(8.6^2))(8.9)='s 2067.93cc's so we would round that up to a 2.1L motor Peace
Old Feb 23, 2003 | 10:47 PM
tnbigdawg's Avatar
which in turns, reduces detonation.
Old Feb 23, 2003 | 11:19 PM
Kataku2K3's Avatar
Default Re: sleeving a b18c1 to 2.0? (tnbigdawg)
Which is exactly why I would have it done... hahaha this is fun...
Old Feb 24, 2003 | 05:20 AM
TimoneX's Avatar
New User
Some big names including Joe Alaniz will advise you against doing this. At least he did me w/ a NA setup.
Old Feb 24, 2003 | 09:31 AM
Henry HA's Avatar
HAnda-Tech Member
WOW..13:1 on pump gas Thats extreme. Do u get alot of detonation?How much octane do u get around there?
Old Feb 24, 2003 | 10:21 AM
BluntMan's Avatar
Default Re: sleeving a b18c1 to 2.0? (B18C_DC2)
actually thats not to extreme. its about borderline. 91 octane should be able to handle 13:1 no prob.
Old Feb 24, 2003 | 11:44 AM
I am finishing building the engine as we speak, I dont know how 13:1 is going to respond to pump gas. We have 93 octane at the pumps in Pa, so i should be ok. All tuning is going to be done via hondata s200, and 440cc injectors.
Old Feb 24, 2003 | 06:53 PM
Tbone's Avatar
My last setup with 13.1 ran on 94oct no problem. My head was tapered spot faced on the outer edges( r head with welded chambers, so only on the sides ) It's actually more like a smooth bevel to 84.
P_t0wn
May 3, 2005 01:19 PM
P_t0wn
May 1, 2005 08:32 PM
redboost10
Feb 11, 2004 07:37 PM
Nikos
11
Jul 5, 2003 02:44 PM
REX VT
Jul 23, 2002 10:20 AM
