Code 91 need help
Old Feb 24, 2003 | 11:29 AM
97CivicTypeR's Avatar
Default Code 91 need help
Hello all, I have a 97 Civic with a 1998 Type-R motor b18c5 and i have code 91. Does anyone know how to fix it? Code 91 is "LOW FEUL PRESSURE IN TANK"
Any replies will be appreciated.
Thanks Marco
97CivicType-R
Old Feb 24, 2003 | 05:51 PM
KiLLa CaM 06's Avatar
Default Re: Code 91 need help (97CivicTypeR)
i have the same problem. Its because the 97 dx civic doesnt have a sensor in the tank area. and the charcoal canister do not have a two way valve on it. to fix it you will have to switch out the gas tank and the charcoal canister. or get a jdm ecu
[Modified by olskodumie, 2:54 AM 2/25/2003]
Old Feb 24, 2003 | 06:34 PM
Tbone's Avatar
I have a 97 teg and have that code . i have replace my purge valve, charchol canister, all the lines... I have given up and deal with the light.
Old Feb 24, 2003 | 07:21 PM
Ekasey's Avatar
Default Re: Code 91 need help (Tbone)
why don't you guys try replacing your fuel sending unit, that seems like a wiser decision then the others
Old Feb 25, 2003 | 04:26 AM
Tbone's Avatar
Default Re: Code 91 need help (eLusive ek4)
Edit ....been there done that .not for this reason though. It has to to with the evap system , there was a recall on 97 tegs because of it I know because I got the recall, but they wouldnt touch my car because on my motor swap...97 teg rs with 99 gsr swap. Its has something with the canister going bad then sucking a peice into the purge valve or vice versa, something like that i beleive.
Old Feb 25, 2003 | 08:17 PM
Ekasey's Avatar
i guess your only option would be to replace the lines and the canister
93accordsleeper
Oct 28, 2008 07:45 PM
mugenboi
Nov 2, 2007 05:12 AM
hondaeg95
Aug 20, 2004 10:20 AM
Jinxed
Oct 18, 2003 04:30 PM
Jinxed
Oct 13, 2003 06:22 PM
