sensor on the JRSC
Old Feb 23, 2003 | 12:59 PM
Zero2Sixty's Avatar
Default sensor on the JRSC
whats the pressure sensor hook up to on the back of the JRSC, the one that has a little wire plug in on it.
Old Feb 23, 2003 | 03:52 PM
keebler65's Avatar
Default Re: sensor on the JRSC (Zero2Sixty)
are you talking about the IAT sensor? the only pressure sensor is the MAP sensor but that doesnt sound like what you're describing.
Old Feb 28, 2003 | 08:09 AM
Zero2Sixty's Avatar
Default Re: sensor on the JRSC (keebler65)
no its a pressure sensor that came with the jackson unit
Old Mar 19, 2003 | 10:44 PM
tegedrex's Avatar
fuel enrichment relay.
Old Apr 3, 2003 | 03:36 PM
Tiamat-blue's Avatar
Default Re: sensor on the JRSC (tegedrex)
What would I do if I didn't get this relay with my used kit? Can I just hook up a 4 wire relay from radio shack?? I have the pressure sensor just not the relay.
Old Apr 3, 2003 | 04:01 PM
keebler65's Avatar
Default Re: sensor on the JRSC (Tiamat-blue)
you could buy my brand new JR relay that i wont be using....
i'm sure any relay should work, as long as you know how to hook it up from scratch.
Old Apr 4, 2003 | 02:43 AM
Thats my question actually. Does the relay use a resistor when open or does it just open the circut? I assume the latter would cause a cel, so probably the resistor. But could I use a "pot" resistor so it was variable?
andrew1
Mar 24, 2010 07:28 AM
nicklk
May 27, 2004 07:29 PM
boosted_zc
Mar 12, 2003 04:11 AM
Civic89
Jun 17, 2002 01:26 PM
JM Performance
Jan 3, 2002 07:17 AM
