cams & Compression ratio
Old Mar 1, 2003 | 02:25 PM
Dorikamu's Avatar
Default cams & Compression ratio
Ok, I am planning to build my ls vtec, and I am planning what parts to use.
I am gonna use b16a2 head on a b18b block... now if I am gonna use b16a USDM piston, the CR will be like
11.639915784025111 : 1, according to c-speedracing calculator.
1) should the b16a2 cams work with this CR? 2)and what cams will work the best in this setup?
Old Mar 1, 2003 | 04:14 PM
InevitableRace's Avatar
Default Re: cams & Compression ratio (chusai)
Your compression will be 11.3 because piston to deck hight is .30 or.29....
Cams you can use but dont take my word for it..
ITR
CTR
Skunk2 stage 1 and 2
Jun stage 1 and 2
Toda A and B
And yes the B16a cams will work just fine for now Untill you get use to it. that will take a week..
-Ross
And i would like to say good choice on Pistons,They are higher Comp then ITR pistons..
Old Mar 1, 2003 | 04:28 PM
RaIn's Avatar
Default Re: cams & Compression ratio (allmotrb18c1)
Mill the the b16 head or Use a GSR head its got higher compression, you can easily change the bad intake mani witha skunk2. And yes your cams will be fine im running it right now, with the same b16a2 pistons.
Old Mar 1, 2003 | 09:54 PM
Dorikamu's Avatar
I am not sure what you mean by "get used to it"...
Old Mar 1, 2003 | 09:57 PM
You'll get used to the Cams and then you will want to go bigger...Thats what i mean..
-Ross
Old Mar 1, 2003 | 10:52 PM
Westrock2000's Avatar
Default Re: cams & Compression ratio (RaIn)
I think the B16a head is actually the smallest in terms of bowl size (not sure, but I think). Also if your like me and actually have to budget things, you may wanna pass up the superfly TODA and JUN stuff and go with Crower, about $650 a pair and they actually have more than 2 pairs here in the states!
Old Mar 2, 2003 | 01:14 AM
Dorikamu's Avatar
Default Re: cams & Compression ratio (Westrock2000)
what does cams do to the block, in terms of stress level? do I need to sleeve the block if I wanna run more agreessive cams? if that's the case, I think I will hold off on that...
esurds
Feb 11, 2010 07:42 PM
tomlinson619
Mar 21, 2006 08:14 PM
JFG Kevin
30
Mar 24, 2005 11:44 PM
jdmcx
Dec 21, 2003 06:34 AM
dabomb
Mar 24, 2003 03:31 PM
