jdm engines sensors
does anybody now if jdm engines that are OBD2 come with crankshaft sensor? are the jdm engines sensors the same as usdm? reason why i'm asking is GA has new emissions that they plug a tester into 16pin dlc obd2 port to read if all readiness codes test ok if more then two show imcoplete your fail. Also if you have a check engine light you fail. thanks for the help.
96BlackHB
Jan 13, 2004 05:53 PM
