fuel pressure problem.
Old Mar 3, 2003 | 11:13 PM
Frankie324's Avatar
Default fuel pressure problem.
I cannot adjust my fuel pressure below 80 psi.
I have an AEM fuel rail and AEM fuel pressure regulator and I upgraded my fuel pump Walboro 255lph. I was suspicious of the AEM FPR and I put my stock FPR back on and no difference. I was advised to make sure the return line was not clogged up and its not. Any other suggestions??? I need this fixed, my car is running too rich and have to get this fixed soon. Any help is appreciated.
Old Mar 4, 2003 | 10:43 AM
t0eKnEe's Avatar
Default Re: fuel pressure problem. (Frankie324)
anybody??
Old Mar 4, 2003 | 10:49 AM
orange.honda's Avatar
Default Re: fuel pressure problem. (t0eKnEe)
hey if the vacuum line that goes to the fpr is broken or leaking it will up psi. or you could have a vacuum leak somewhere else in the intake manifold but then it would only be rich and then lean and then rich. i would check the vaccume lines.
Old Mar 5, 2003 | 12:33 AM
Frankie324's Avatar
Default Re: fuel pressure problem. (orange.honda)
no, there is no leaks on the intake manifold and the vacume line that goes to the fpr is fine. if the return line is fine where else can i try.
sure i can take it somewhere and let them take care of it, but is there anything else I can try???
Old Mar 5, 2003 | 08:48 AM
t0eKnEe's Avatar
somebody? help out a fellow ricer
Old Mar 5, 2003 | 04:10 PM
Frankie324's Avatar
i took the regulator out and took it apart and there seems to be nothing wrong with the regualtor. i pinched the return line that comes off the regulator and the fuel pressure rises even more, so at least that tells me that its not clogged there.
any suggestions??
i need some help.
Old Mar 5, 2003 | 09:46 PM
t0eKnEe's Avatar
anyone??
Old Mar 6, 2003 | 03:34 AM
3gdude's Avatar
Maybe you could run a line between the pressure hose coming from the pump over to the return line and put a fixed orifice in it, so it returns more fuel to the tank....3gdude
Old Mar 17, 2003 | 06:25 AM
Frankie324's Avatar
Default Re: fuel pressure problem. (3gdude)
well, i took the fuel pressure guage out and its at 60 psi!! the fuqken guage is bad!! who knows how much fuel pressure i was really running.
turboef90
Aug 11, 2013 12:28 PM
polishedturd
54
Jun 5, 2008 02:00 PM
integrals1289ss
Oct 7, 2007 10:20 AM
hyabusa hunter
Jun 7, 2007 12:55 PM
hybrid_vtec
Aug 27, 2004 10:02 AM
