head stud install
Old Mar 4, 2003 | 10:54 AM
ScottFern's Avatar
Default head stud install
I have a b18c in my 94 hatch. I just got ARP head studs.
do i torque the studs into the block before i torque the head bolts onto the head?
Old Mar 4, 2003 | 11:31 AM
Wicked Sol's Avatar
New User
Default Re: head stud install (ScottFern)
No. All I did was double nut the stud then just tighten them down hand tight with a 3/8" wrench. I've don't it like this 4 or 5 times and never had any problems. Make sure you have a 13 point deep well to tighten the head down. Just about every time I use a shallow it will bottom out and then have to run into town and buy a deep well.
Old Mar 4, 2003 | 11:37 AM
Kataku2K3's Avatar
Default Re: head stud install (Wicked Sol)
Yup that's what I always do to, tighten down two nuts on each other and then torque them down... I always torque the studs into the block at 30ft/lbs. Good Luck
Old Mar 4, 2003 | 01:58 PM
EVOCELICA's Avatar
New User
Torque them dowm
Old Mar 4, 2003 | 04:42 PM
Chiovnidca's Avatar
Hand tight with a wrench??? Where did you get that 13 point socket???
Old Mar 4, 2003 | 05:09 PM
10K2HVN's Avatar
Default Re: head stud install (D16Chiovnidca)
yeah..i was wondering the same thing but didnt say anything earlier...i was under the impression that you just hand tighten (with your fingers) the studs then slap the head on and torque down the nuts..???
Old Mar 4, 2003 | 06:58 PM
IN VTEC's Avatar
Default Re: head stud install (10K2HVN)
The instructions say to install them hand tight, and hand tight only.
But, quite a few people double-nut and torque them down. I did mine at 10lb*ft, but I think if I had to do it again, I'd use 7lb*ft with a 3/8" in*lb torque wrench instead of the bigger lb*ft torque wrench.
The point of torquing them down is to ensure that the studs are seated all the way down into the block, to minimize the risk of the nut bottoming out and not being able to hold the head with enough compression force to prevent blow-by or fluid leakage.
Forgot to mention taht you should go through a tightening/loosening sequence twice before performing the final torque down. This will stretch the studs beforehand.
[Modified by IN VTEC, 10:02 PM 3/4/2003]
Old Mar 5, 2003 | 08:54 PM
10K2HVN's Avatar
Default Re: head stud install (IN VTEC)
..got it, Thanks
...some people say to torque it down 3 times.....
Old Mar 5, 2003 | 09:35 PM
RICE POLICE SIP's Avatar
Old Mar 5, 2003 | 09:45 PM
Sonny's Avatar
I did mine to 10 ft-lb with the double-nut method.
People who do finger tight sometimes have problems with the studs backing out. Also, at finger tight only, the studs were not all sitting at the same height.
Sonny
95_red_dc
Aug 31, 2008 09:28 AM
boomersz
Feb 24, 2007 09:56 AM
ivt-t
Feb 8, 2007 09:15 PM
george34
Feb 18, 2006 05:05 AM
LudEcrous
May 4, 2004 01:47 PM
