VTEC activation Switch ????
Old Mar 3, 2003 | 11:20 AM
eg6madness's Avatar
Default VTEC activation Switch ????
were can i get a VTEC activation switch ?
how do i hook it up and how does it work ?
Old Mar 3, 2003 | 01:52 PM
badCRX's Avatar
New User
Default Re: VTEC activation Switch ???? (eg6madness)
You can get an MSD RPM activated switch to activate the VTEC solenoid at a certain RPM. What motor are you using along with ECU?
Old Mar 3, 2003 | 02:00 PM
Kamin's Avatar
Default Re: VTEC activation Switch ???? (badCRX)
bad idea
dont do this
without the proper ecu (wich is why im assuming you are using a switch)
you wont have the proper fuel maps for vtec and could damage the engine.
Old Mar 3, 2003 | 02:03 PM
RAWB's Avatar
Default Re: VTEC activation Switch ???? (Kamin)
bad idea
dont do this
Old Mar 4, 2003 | 12:55 PM
eg6madness's Avatar
Default Re: VTEC activation Switch ???? (RAWB)
i since i can afford ITBs at the moment i was plannin to use carbs ( i was always a fan of carbs on other cars ), and always wanted to put them on a VTEC motor but since i knew that VTEC uses the ECU i figured that they will not be able to fit. but i saw the post about VTEC and carbs but have no idea how to make them work together.
I hear i can use a VTEC activation switch and it'll work but i have no idea how to make it work with carbs.
Any ideas?
Old Mar 4, 2003 | 02:18 PM
badCRX's Avatar
New User
What motor are you wanting to put carbs on? It sounds like you are trying to add VTEC to any motor. You can run carbs, individual throttle bodies, dual throttle bodies, or a single throttle body on any motor. We need to know what motor you are working with though.
Old Mar 4, 2003 | 06:31 PM
eg6madness's Avatar
I am working with the D15b SOHC VTEC . i may be mating the D16 sohc vtec head . how will the carbs and vtec work together ? how does the vtec activation switch work and allow thevtec to engage ?
Old Mar 5, 2003 | 07:52 AM
badCRX's Avatar
New User
I take it you are doing a mini-me? You might want to ty and find someone that works with carbs as to how to setup your fuel system. That is foreign to me. You can use a MSD rpm activation switch to turn on the VTEC. Most people using stand alone engine management systems use it for the very same thing.
Shoot5Hole84
Apr 17, 2010 10:20 PM
regal1975
13
Apr 13, 2007 06:00 PM
philkehn
10
Oct 3, 2006 11:55 AM
Imprezor
16
May 10, 2005 03:05 PM
hOndafienD 04
Jan 1, 2005 02:13 PM
