too late for turbo?
Old Mar 1, 2003 | 04:50 PM
pete332's Avatar
Default too late for turbo?
i have 150K on my 95 GSR, is it too late for me to slap a turbo on it?
Old Mar 1, 2003 | 04:54 PM
joe_bocc's Avatar
Default Re: too late for turbo? (LSb0y)
I don't think its ever really too late to turbo your car, but you may not have top-notch performance or reliability. As long as you run reasonable boost levels I think you would be OK.
Old Mar 1, 2003 | 06:44 PM
hotintegranights's Avatar
Default Re: too late for turbo? (joe_bocc)
as long as you maintained your engine all these years i would say you can run at least 7-8 psi on it tops,with a intercooler and bov and fuel system setup.
or rebuild with better components and low compression pistons and run 12psi or more
Old Mar 2, 2003 | 10:10 AM
delslow94's Avatar
Default Re: too late for turbo? (hotintegranights)
it all depends on the condition of the motor. if your rings are good and pistons also along with every other component you should be ok. mileage doesnt limit your ability to do something its the condition of the components. if you have the money tho i would definately change the rings and bearings inside the motor. those can easily die on a higher mileage motor, it will also give you a chance to inspect all the parts.
Old Mar 2, 2003 | 12:10 PM
genetsang's Avatar
like everyone is saying.... depends on the condition of the motor.....
if its decent shape... you will be looking at antother 50k on the motor b4 it goes POOOOOOF
Old Mar 2, 2003 | 12:52 PM
sslude's Avatar
Default Re: too late for turbo? (genetsang)
just replace parts (that are worn) with newer things, thats what i would do.
Old Mar 2, 2003 | 05:05 PM
SMZ GSR's Avatar
Default Re: too late for turbo? (sslude)
exactly what i'm gonna do. my GSR has about 100k, but i'm getting a rebuild at the same time as install.
Smily0087
Mar 20, 2010 05:37 PM
toukao35
Mar 15, 2010 01:00 PM
Bignel00
Dec 17, 2007 04:47 PM
Jake92eg
May 10, 2006 04:59 AM
redluder
Jun 29, 2002 02:19 PM
