SOHC internals. best?
Old Mar 1, 2003 | 05:21 PM
Irishweird00's Avatar
Banned
Default SOHC internals. best?
I'm uppin my compression but not sure how much.... I have a stock d16y7 and want new pistons, rods and cams.... did alot of searching but not alot for my engine... where can i get a good deal>? i.e JE, arias, crower, crane......ect
[Modified by Irishweird00, 2:21 AM 3/2/2003]
Old Mar 1, 2003 | 05:43 PM
Banned
Default Re: SOHC internals. best?
Was thinking, Je pistons... not sure the compression ratio.... 10-11.. eagle h beam rods, and a crane cam.. and gear... what you think... for starters?
[Modified by Irishweird00, 3:25 AM 3/2/2003]
Old Mar 1, 2003 | 07:08 PM
Banned
While im workin... someone can give me an opinion
Old Mar 1, 2003 | 08:24 PM
untitled's Avatar
Default Re: SOHC internals. best? (Irishweird00)
heres a good site to goto if your building a d. http://www.dh-racing.com
Old Mar 2, 2003 | 06:48 AM
robbieshonda's Avatar
Default Re: SOHC internals. best? (88crx91integra)
sup man? if you just want to bump it up. a honda has a 3 layer head gasket. take one of the layers off it will bump up the compression. not sure how much but its a proven tip.
good luck.
Old Mar 2, 2003 | 08:41 AM
CivicSoul's Avatar
Default Re: SOHC internals. best? (robbieshonda)
Unless you are goin to boost, use the A6 pistons on your motor and call it good to go. If you are trying to get a N/A set up on the d16y7, it is going to cost you an arm and a leg. Save for boost! do not get JE pistons, and there is no need for the eagle rods, unless you are waning to waste your money. You can build a cheap turbo kit for the price of rebuilding your engine.
BlkChryKord
Nov 6, 2006 11:35 AM
BLK99VTECR
16
Jan 19, 2005 06:32 PM
RangerJoe
Jan 28, 2004 05:34 AM
beandip
Nov 12, 2002 10:49 PM
rrei
Oct 29, 2002 08:34 PM
