b20vtec injector ?
Old Mar 3, 2003 | 06:15 PM
na200whp's Avatar
Default b20vtec injector ?
im putting together a b20vtec w/ 12:1 compression endyne pistons, ported b16cyl head w/ type r valves & springs, skunk stage 1 cams & in manifold, & CAI header exh. my ? is will 97 lude injectors (270cc-290cc not sure) be large enough using hondata? and will my stock 2000 si fuel pump keep up as well ? im not asking if i should go bigger because i know it would be better but i already have these and just want some in put. thanks for any feed back .
[Modified by na185whp, 3:40 AM 3/4/2003]
Old Mar 4, 2003 | 01:02 AM
CRVTEC96's Avatar
Default Re: b20vtec injector ? (na185whp)
I suggest you go Bigger. I know that your stock fuel system will run lean. So just upgrade, Remember Fuel is probably the most important thing in a engine!
Old Mar 4, 2003 | 04:02 AM
Charlie Moua's Avatar
Default Re: b20vtec injector ? (CRVTEC96)
damn all these B20vtec & LSvtec questions...
use search bro.
I would go with regular Dohc vtec injectors for anything under 210whp
anything above... I'd go RC 310cc
fuel pump?
you'll need it if your makeing more than 200whp
get a walbro 225.
B16a2Em1
Oct 16, 2015 04:20 PM
negusjuda
Feb 6, 2010 01:42 PM
2-logicl
Aug 1, 2006 04:15 AM
redGSRguy
Feb 15, 2006 02:23 PM
jeremy.
Sep 29, 2003 05:35 PM
