engine squeeling
Old Mar 1, 2003 | 01:06 PM
See Are X's Avatar
Default engine squeeling
aight, I just dropped in a 95 GSR in my crx, I have yet to get the motor started. But while messin around with it, I noticed a squeel coming from the motor when I turn the crankpulley. I took the timing belt off the cam gears so I know it's coming from the bottom end. Also, it will only squeel when cylinder #1 and #4 are on its upward travel. Is this something I should be concerned about?
Old Mar 1, 2003 | 01:42 PM
Kamin's Avatar
Default Re: engine squeeling (See Are X)
no
thats just the sound an engine makes when you turn it by hand. (unless the sound is EXTREMLEY loud, if its a quiet phsssssss sound on the compression stroke, its normal)
Old Mar 1, 2003 | 02:00 PM
Bailhatch's Avatar
Default Re: engine squeeling (Kamin)
dry rings maybe? drop a litle oil in each cylinder (may as well do a comp test too) and see if it stops or gets quieter. I bet thats it. unless it is air rushing in and out then it is normal.
Old Mar 1, 2003 | 02:17 PM
94TealGSR's Avatar
I wouldn't be worried about it untill you start the motor. So long as you can turn the motor by hand smoothly then you're fine.
szvsce
Sep 7, 2018 05:23 PM
jdecks23
Mar 19, 2014 05:30 AM
h22 kid
Dec 15, 2010 10:37 PM
vtibrazil
Dec 31, 2008 08:01 AM
pbcdb
Jan 21, 2004 11:18 AM
