smogging jdm engines
Old Mar 3, 2003 | 05:55 PM
wildstallion's Avatar
Default smogging jdm engines
i have a question... although i have no experience with trying to smog a jdm engine, ive heard that they wont pass the smog tests. i was wondering if there were any way to get around this, like hookin up a usdm ecu onto the jdm engine, maybe this will do the trick. anyways that is all.
Old Mar 3, 2003 | 05:58 PM
asmallsol's Avatar
Default Re: smogging jdm engines (wildstallion)
You can get a JDM engine to pass smog tests. What you have to do is replace all the JDM emmission controls (or lack there of) with USDM compontnets. Also running a USDM ECU is a must. Some little tricks other than slipping some guy from northern cali a 50 is to keep your car running as much as possible before the testing (cats work better when they are hot) Clean your air filter, run new plugs and wires. Do a google search and you can find a decent amount of info on this.
Also run it with a lower octane gas, higher octane gas does not burn completely which results in higher levels of gas in your exhaust.
[Modified by asmallsol, 2:59 AM 3/4/2003]
Old Mar 3, 2003 | 06:07 PM
Lord Helmet's Avatar
contact spade and do a search there is alot of info pertaining to this subject. spade made a thread that deals with smogging a jdm engine.
and yes jdm engines are smogable.
[Modified by sleeperciv, 7:40 PM 3/3/2003]
Old Mar 3, 2003 | 06:21 PM
Default Re: smogging jdm engines (sleeperciv)
thanks, that was fast as a ****, went to drop a deuce, came back, and plooooowwww, 2 replys. sorry for not searching first.
Old Apr 5, 2005 | 09:17 AM
TallAssFilipino's Avatar
Default Re: smogging jdm engines (asmallsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asmallsol &raquo;</TD></TR><TR><TD CLASS="quote">You can get a JDM engine to pass smog tests. What you have to do is replace all the JDM emmission controls (or lack there of) with USDM compontnets. Also running a USDM ECU is a must. Some little tricks other than slipping some guy from northern cali a 50 is to keep your car running as much as possible before the testing (cats work better when they are hot) Clean your air filter, run new plugs and wires. Do a google search and you can find a decent amount of info on this.
[Modified by asmallsol, 2:59 AM 3/4/2003]</TD></TR></TABLE>
Was able to pass emissions finally after replacing cat' while maintaing all JDM OEM parts.
Bulli Kid
Apr 14, 2007 03:51 PM
NsX_CrX
Aug 25, 2005 08:05 PM
Filliam H. Muffman
12
May 18, 2003 01:25 PM
PyroGSR
Nov 5, 2002 07:24 PM
futbol84
Jul 29, 2001 06:50 PM
