ITR vs CTR 5-lug conversions
Old Mar 4, 2003 | 06:49 AM
Propulsion's Avatar
Default ITR vs CTR 5-lug conversions
is there any difference between the rotor size or brake design?
also, if I have an ek, would the ctr 5-lug be the better choice for fitment?
Old Mar 4, 2003 | 09:41 AM
Propulsion's Avatar
Default Re: ITR vs CTR 5-lug conversions (SilverCIVIC96)
someone's gotta know this
Old Mar 4, 2003 | 10:05 AM
sgT's Avatar
sgT
rotor and calipers are identical
if the EK9 and EK4 front spindles are the same then they are different than DC2
Old Mar 4, 2003 | 11:42 AM
Kataku2K3's Avatar
Default Re: ITR vs CTR 5-lug conversions (sgT)
Watch it on the JDM DC2 98+ 5 lug... They run the 36mm hub which only accepts a 36mm axle... My friend had the 36mm **** on his 97 GSR turbo coupe and he kept snappin axles so it was a real pain in the ***... USDM **** is just a lot easier if you are worried... Peace
Old Mar 4, 2003 | 01:37 PM
10K2HVN's Avatar
Default Re: ITR vs CTR 5-lug conversions (Kataku2K3)
could you just but a USDM hub from acura and replace it...?
Old Mar 4, 2003 | 04:39 PM
Katman's Avatar
Default Re: ITR vs CTR 5-lug conversions (10K2HVN)
or use CRV axles?
Old Mar 5, 2003 | 10:00 AM
Propulsion's Avatar
could someone elaborate on the axle information? So which year ITR or CTR 5-lug should I be shopping for?
Old Mar 5, 2003 | 10:22 AM
Kataku2K3's Avatar
For JDM Teg, 96-97... I'm pretty sure that the CTR ran the standard 32mm hub the entire time so you should be okay there... (double check tho, I could be wrong) and all USDM ITR 5 lug... It's the same as 96-97 JDM... Peace
Old Mar 5, 2003 | 12:00 PM
joe_bocc's Avatar
From my understanding, you can get any CTR 5-lug and any USDM 5-lug. The main difference between these 2 would be that you would reuse your stock LCA with the ITR.
Try to avoid the 98+ ITR 5-lug because of the larger axles, hubs, etc.
EDIT-grammer
[Modified by joe_bocc, 9:16 PM 3/5/2003]
Old Mar 5, 2003 | 12:12 PM
migs's Avatar
Default Re: ITR vs CTR 5-lug conversions (joe_bocc)
Maybe I can help
96JDM ITR = 4x114.3 lug pattern, sorry folks, not 5 lug, but it DOES have the 32mm hub nut
98+ JDM ITR all use the 5x114.3 setup. The 36mm hub nut is found on ALL 98+ spec units. I have a friend who used a "90-92 Accord axle" Dont hold it against me cause Im not sure myself, thats what he told me.
ALL CTR's have the 32mm hub nut. You CAN put the CTR 5lug on ANY EK, EG, DC chassis, front and back.
USDM ITR setup is the same as the CTR
[Modified by Migs, 6:02 PM 3/5/2003]
Old Mar 5, 2003 | 05:38 PM
Propulsion's Avatar
Default Re: ITR vs CTR 5-lug conversions (Migs)
thanx guys for clearing that up, one more question though,
I plan to get a ITR swap w/ at the same time as the 5-lug from the same place (passwordJDM), so if if this is a 98+ jdm ITR motor, I would just get the 98+ ITR 5-lug (36mm) right?
Would the CTR 5-lug (32mm) work w/ this ITR motor too? or will I need ctr axles?
Old Mar 5, 2003 | 06:32 PM
B20Monster's Avatar
the 36mm hub came with the ITR's with the 16 in rims.. there are 98+ 5 lugs that use the 32mm nut too.
Old Mar 5, 2003 | 07:34 PM
migs's Avatar
Default Re: ITR vs CTR 5-lug conversions (B20Monster)
Thats CTR, NEVER ITR.
SoCal EJ1
May 13, 2008 01:01 PM
tr0n9h
Dec 10, 2006 09:36 AM
mdj_ge
Nov 4, 2004 12:10 AM
jdmjohn02
Jan 12, 2004 12:03 AM
GoldenONE
Jan 21, 2003 12:38 PM
