Where does this line Go? someone help
Old Mar 3, 2003 | 08:57 PM
TheJediMex's Avatar
Default Where does this line Go? someone help
so im rebuilding my car and i bought a 97 b18c1 gsr motor for my 97 acura integra(check my sig for pics)
but i see a line coming from the back of the TB and dont know where it goes. from the pics below i can see it connect's to another line but where does that other go to????
Ps sorry for your using your engine bay pics but they are the best i have found
Any help would be greatful or some sort of diagram too...thanx in advance
Again sorry for using your engine bay whoever this is...
Old Mar 3, 2003 | 09:06 PM
Therumblingteg's Avatar
Default Re: Where does this line Go? someone help (JdmTeg97)
that looks like it goes to the brake booster.
Old Mar 3, 2003 | 09:33 PM
TedR719's Avatar
Default Re: Where does this line Go? someone help (Therumblingteg)
Break Booster
Old Mar 3, 2003 | 10:12 PM
IM ALL BOB's Avatar
I concur it is for the brake booster
Old Mar 3, 2003 | 10:29 PM
TheJediMex's Avatar
Default Re: Where does this line Go? someone help (IM ALL BOB)
may i ask what this hose does???. as for its coming out of the TB???
Old Mar 3, 2003 | 10:31 PM
mmuller's Avatar
Mad Scientist
Its vaccum for the brake booster, the grey thing in the middle is a check valve i believe
Old Mar 3, 2003 | 10:48 PM
TheJediMex's Avatar
Default Re: Where does this line Go? someone help (mmuller)
ok i somewhat understand a bit.. if it is a vacuum, whats it sucking out of the brake booster???
Old Mar 4, 2003 | 03:09 AM
Chiovnidca's Avatar
It supplies vacumn to the booster so that you power brakes work.
Old Mar 4, 2003 | 07:37 AM
577HondaPrelude's Avatar
Default Re: Where does this line Go? someone help (D16Chiovnidca)
it's not really sucking to make air flow out of your booster, it just used to make a negative pressure (no real air flow).
Old Mar 4, 2003 | 11:49 AM
TheJediMex's Avatar
Default Re: Where does this line Go? someone help (57STS)
wow thanks so far.. im gonna have to fix this asap as for i feel like the brakes aint working anyways mad hard to press them
could this be beause of that hose?
[Modified by JdmTeg97, 12:49 PM 3/4/2003]
Old Mar 4, 2003 | 11:54 AM
Kataku2K3's Avatar
hahaha, yup that's it... get it fixed and you should be set... Latez
Old Mar 4, 2003 | 11:59 AM
TheJediMex's Avatar
Default Re: Where does this line Go? someone help (Kataku2K3)
could this be beause of that hose?hahaha, yup that's it... get it fixed and you should be set... Latez
thanx im gonna take some pics of my engine bay so people can tell me where some other things go...
thanks for the tech help...
Old Mar 5, 2003 | 03:17 PM
migs's Avatar
If its hard to press, your brake booster has probably failed. Check to see if that check valve is flowing the right way. It MIGHT be working against it.
danedoremus
May 23, 2012 04:39 AM
cityofcaterpillars
Jun 12, 2010 02:15 AM
Fuster_Cluck
Mar 9, 2008 04:41 AM
gotsmokedright2
Jan 23, 2004 07:15 PM
98R-1144
Mar 21, 2003 04:28 AM
