NEED some info and help ...
i got a 93 hatch with a 95 ls motor ... im planning to ls/vtec within the next month ... im prob gonna go with the b16 head with probably mild cams but not sure which ones to go with ? ... and build the bottom end but not sure wether to go with the ITR pistons or JE or Arias pistons ? i dont want to high of a CR ... since my car is still gonna be daily driven ... i was also told eagle rods would be best ? ... and i wanted to run like a 50 shot possibly ... any thoughts on which nos kit is better ? or are they pretty much all the same ? ... o and what tranny would be best ? ... i was considering the spoon tranny ... i want to hit mid 13's possibly ... let me know your thoughts ... any help would be greatly appreciated ...
If you planning on a 50 max. then new rods aren't really necessary. If you only want a mild set of cams, ITR cams might be nicely suited for you. If you don't want a CR that is too high, maybe you could consider the USDM ITR pistons. Just some thoughts
