Help with clutch install!
Old Mar 4, 2003 | 02:39 PM
ridestrt's Avatar
Default Help with clutch install!
I have my clutch installed and I can easily move the lever on the tranny by hand. I put a new throw out bearing in, maybe I did not install it right? Does anyone know why it is so easy to move the lever? This is a cable tranny J1. Thanks
Old Mar 4, 2003 | 02:48 PM
Kamin's Avatar
Default Re: Help with clutch install! (NMcivicEF)
what the hell are you talking about?
the shift fork moving the release bearing?
its supposed to move easy
and you arent gonna be able to push it into the clutch and actually cause the clutch to engage because it requires hundreds of pounds of force to engage the clutch.
Old Mar 4, 2003 | 04:47 PM
Bailhatch's Avatar
Default Re: Help with clutch install! (Kamin)
if you mean the lever on the outside of the tranny case how far does it move? a little play at the bottom is fine. It will stop abruptly an inch or so up from the bottom. If it goes all the way up by hand then you messed up. Pull it and check your work.
Old Mar 4, 2003 | 05:06 PM
tegsol1's Avatar
well if it moves completly with out any force you probably forgot the pressure plate
Just playin but it should have slight play
dcturbols
Honda S2000
May 6, 2007 06:18 PM
1fastdc2
May 13, 2006 05:10 AM
steve_s
Apr 20, 2003 05:06 PM
