Piston to Valve Contact?
Old Mar 1, 2003 | 08:42 PM
McFly's Avatar
Default Piston to Valve Contact?
I have a B16a block that has NOT been decked and a GSR head that has been decked .037" and CTR pistons with factory 3 layer head gasket. I am wandering if I can install CTR cams with out having to worry about piston to valve contact. Don't want to pull the motor apart to clay it. Thanks
Old Mar 1, 2003 | 11:45 PM
MikeSarr_GSR's Avatar
Default Re: Piston to Valve Contact? (UnderFire)
the B16a has less stroke, with a shorter deckheight... the CTR pistons are made to work in that block. milling almost 1mm off the head is a risk for cam tuning, you would have to retard the cams to -2IN, -2EX to get back to 0,0. Thats alot to mill the head w/o wanting to clay the motor. The valve reliefs on the CTR pistons are pretty deep... however I would still run the cams... only really being sure to be conservative on the cam settings. -2 to +1 on intake and 0 to -2 on exhaust would be my limits... anything bigger on the cams other than CTR, maybe skunk stage 1 would work fine... I would steer clear of... anything larger than 11.5mm@ the valve!! definately use ARP head studs, a solid valve spring and the stock HG...
let us know how it turns out!!
Old Mar 2, 2003 | 04:27 AM
McFly's Avatar
Default Re: Piston to Valve Contact? (MikeSarr_GSR)
Thanks for the reply. I'll be sure to keep that in mind. I plan to use the head studs anyway. Is there any other way to check the clearance on the motor without claying it?
Old Mar 2, 2003 | 04:46 AM
Neukin's Avatar
so for a 1mm bump up its +2I and +2E... i put in a toda metal headgasket and its 1mm so i adjusted the gears alittle but now that i know excatly ill be better off thanks
Old Mar 2, 2003 | 08:14 AM
jcda6's Avatar
You can get a depth micrometer and check that way.
-Jeff C.
Old Mar 2, 2003 | 11:32 AM
McFly's Avatar
Default Re: Piston to Valve Contact? (jcda6)
how is a depth micrometer used?
Old Mar 2, 2003 | 08:01 PM
FYI, I have been taught that removing material from the gasket area makes the cam see an effective advance... since the clearance is TIGHTER. It would make the motor see cam lift/valve opening/closing specs SOONER in relation to TDC if not compensated for. not the other way around. correction for removal of material is a retard on the cam gear, not an advance to maintain a 0,0 cam setting.
shandonwall
18
May 29, 2009 05:35 AM
Tech6023
Sep 12, 2005 09:26 PM
temp
Jul 25, 2004 01:50 PM
civic1320
Jul 24, 2003 11:33 PM
