my DIY catchcan...
Old Mar 1, 2003 | 05:58 PM
baonest1's Avatar
Default my DIY catchcan...
well took like 30 min to do. got all the supplys free from homedepot. from a friend. its empy now. i have some steel wool to put inside. whadya think. i was bored. so thats why i did it.
Old Mar 1, 2003 | 06:15 PM
Cuong-nutz's Avatar
Default Re: my DIY catchcan... (baonest)
Chit looks cool! How would you clean it out? Pop the top? Are the brass fittings screwed on from the inside and outside? here's a beer for the work
Old Mar 1, 2003 | 06:25 PM
baonest1's Avatar
Default Re: my DIY catchcan... (Cuong-nutz)
thanx..
the fittings are screwed from outside.. i made the hole as big as the fitting and forced it in there.. so i basically tapped the PVC with the fitting. i put JBweld around the area. about the cleaning.. i dont know really. i just have that drain. it was practically free so i could use it for a while. and just scrap it.
Old Mar 1, 2003 | 06:50 PM
Therumblingteg's Avatar
damm thats pretty good ow much did it cost total.
Old Mar 1, 2003 | 07:01 PM
baonest1's Avatar
Default Re: my DIY catchcan... (Therumblingteg)
dont know how much the pvc cost. they had extra peices.. so i cut them. the 2 brass hose things cost like 2 bux each.. and the release fitting cost i think 4 bux. i alsready had glue and jb weld.
Old Mar 1, 2003 | 07:19 PM
LshatchTurbo's Avatar
New User
haha jb weld rocks!
Old Mar 2, 2003 | 07:27 AM
baonest1's Avatar
the nozzles on the top are not too close together are they...
Old Mar 2, 2003 | 07:59 AM
integra6650's Avatar
whats the actual purpose of a catch can is is to keep the environment clean cause i just let the stuff drain strait from the motor but i do have a csi catch can layin around not sure if im gonna use it
Old Mar 2, 2003 | 11:23 AM
baonest1's Avatar
Default Re: my DIY catchcan... (integra6650)
man.. the thing is nice.. its all dried and i blew air in it... tight seal. the undercap isnt glued on yet. i ahve about 2 peices of steel wool. should i pack the hell out of it.. or just put it in there so it has some space
Old Mar 2, 2003 | 07:15 PM
I think the inlet should be in the bottom, that way it has to travel to the top, and oil will get caught up in the steel wool more. But in any case it is very impressive.
Old Mar 2, 2003 | 07:37 PM
baonest1's Avatar
good point on the inlet... i was thinking about that. i might make another.
a friend brought up a good point.. if for some reason the pvc starts melting. the vapors are deadly. so ima either mount it no where near heat.. or just not mount it.
Old Mar 2, 2003 | 08:58 PM
KStuned's Avatar
So you spent a bunch of time to find all the parts and then to build a ghetto (but functional) one when you could just buy an nhra legal Moroso catch can from summit racing for $26! But hey you did it yourself right?! Good for you.
.::Lee::.
Jan 24, 2006 08:33 AM
ineedhelp
Welding / Fabrication
15
Apr 2, 2005 05:56 PM
B18Flip
Apr 1, 2003 04:42 AM
morepoop4u
Nov 17, 2002 12:09 AM
Trigun
Jun 17, 2002 03:20 PM
