Where to get flywheel lightened?
Old Mar 2, 2003 | 07:25 PM
ChiBoy's Avatar
Default Where to get flywheel lightened?
I have a stock ITR flywheel that I want to lighten to about 12.5lbs. (I think it's 14# now and needs resurfacing anyway)
I would ship anywhere in the US rather than hand it over to the local boys with no experience points.
Can anyone recommend a place that knows what they are doing with these flywheels?
Thanks.
Old Mar 3, 2003 | 04:35 PM
ChiBoy's Avatar
Default Re: Where to get flywheel lightened? (ChiBoy)
Bump
Old Mar 3, 2003 | 07:10 PM
ChiBoy's Avatar
Everyone talks about having it done. Where did you go? Would you go again??
Old Mar 3, 2003 | 11:24 PM
jcda6's Avatar
Your local machine shop should be able to do it in house, or send it out to another shop to have it lathed with your specification. Note, stock flywheels shouldn't be lightened to anything less than 12lbs. Going beyond that threshold will risk the integrity of the flywheel.
-Jeff C.
Old Mar 4, 2003 | 09:33 AM
ChiBoy's Avatar
Default Re: Where to get flywheel lightened? (jcda6)
That's the problem: I don't have a spec. I would like to find a shop with at least some experience. I think sending it to just ANY shop is asking for bigger trouble. Some will argue that lightening a stock fly is asking for trouble to begin with, so why make it worse by letting someone learn on my stuff.
I'm only looking to take a couple of pounds off. 12-1/2 to 13 or so. Nothing drastic like tring to get it down to 8.
Old Mar 4, 2003 | 01:21 PM
genetsang's Avatar
get the ACT street lightened flywheel.... it weighs the same as the amount you want it to weigh... 12 lbs.... you always hear that if lighten a stock fly... if might warp, crack....... so if i was you get a lightened one.. cost almost the same amount to lighten your ITR... and it is still brand spankin new when you put it on...
Old Mar 10, 2003 | 11:27 AM
JPX's Avatar
JPX
Default Re: Where to get flywheel lightened? (genetsang)
not really worth the risk.
Better to get new Lightened Flywheel check out UR Ultra L piece (8lbs)
Replaceable heat shield and zero balanced..
Its like bolting on 22hp to the wheels...
Had mine for over 4yrs...Just love it....
shahriar35
Jan 20, 2011 02:57 PM
96teg831
Northern California
Sep 21, 2010 09:45 PM
civic-one
Jan 20, 2010 05:48 PM
extreme95gsr
Aug 20, 2004 09:06 PM
Rusty Shackleford
Apr 10, 2003 03:17 PM
