Advice on passing inspection
Am I going to be able to pass inspection witht the following set up??
'97 Re-built GSR w/
Golden Eagle Sleaves bored to 84mm
Wiseco 11:8.1 Pistons
Skunk2 Stage 2 Cams
Portflow Vavletrain
Portflow Port & Polish with ITR Intake Valves
JDM DC 4-1 Header
Hondata Stage 2
440cc injectors
If not, any suggestions advice??
Thanks!
'97 Re-built GSR w/
Skunk2 Stage 2 Cams
Portflow Vavletrain
JDM DC 4-1 Header
Hondata Stage 2
440cc injectors
Thanks!
Lean it out, and make sure you have them run the car at about 3000 rpm for a min before they do the test. Had to do that on mine to make sure the cat was warmed up enough for it to work properly.....
I *think* leaning it out is better
Hybrid96EK
38
Dec 29, 2004 02:40 PM
TeamSTEALTH GSR
12
May 12, 2004 12:40 PM
