shifting is hard
Old Mar 4, 2003 | 06:01 PM
blkbeast's Avatar
New User
Default shifting is hard
i have a 94 integra with about 85k on it. the clutch has never been replaced. anyway, after taking a long trip, i noticed that shifting got noticably harder. even putting the car in first was difficult. sometimes i would grind also. this happened with every gear, 1-5.
i'm guessing my clutch is going or my sychros are messed. i was going change the tranny fluid hoping that would solve the problem but i haven't had any time. i drove the car like this for about 1.5 months. i know
on the way home today, i stalled with the clutch fully depressed! i started the car again and my tranny shift's like butter now! wtf?? what's going on? any suggestions? i hope i'll just have to change the fluid.
Old Mar 4, 2003 | 06:48 PM
poison's Avatar
Default Re: shifting is hard (blkbeast)
you answered your own question.
Old Mar 5, 2003 | 05:05 AM
JimBlake's Avatar
Maybe your clutch needs to be bled? Sounds like it doesn't always disengage completely.
Old Apr 9, 2003 | 01:33 PM
blkbeast's Avatar
New User
whoa, i totally forgot about this thread. well here's the update... i still haven't done anything to the teg. sometimes at a light, it would lock me out of all gears. i would turn the car off and on again, and then it would shift. you said i answered my question but which was the answer? changing the tranny fluid?? i hope so
Old Apr 10, 2003 | 04:21 AM
JimBlake's Avatar
Maybe, but I vote for bleeding the clutch fluid. It sounds like your clutch is dragging, means it doesn't disengage completely. Then the synchros lock you out of gear. I bet when that happens, if you try reverse it'll grind rather than block you out. That's 'cause reverse doesn't have a synchro.
Do the cheap stuff first, clutch fluid & transmission fluid. But you might have to replace your clutch master cylinder if it keeps leaking down. When it works, does your clutch engage smoothly, or does it shudder as you engage it? If it shudders, then maybe you need the clutch itself.
Old Apr 10, 2003 | 06:07 AM
T3's Avatar
T3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkbeast &raquo;</TD></TR><TR><TD CLASS="quote">the clutch has never been replaced </TD></TR></TABLE>
Get a new one if changing fluid doesnt work.
Old May 4, 2003 | 02:06 PM
blkbeast's Avatar
New User
Default Re: shifting is hard (T3)
it's getting worse.... i guess i have to replace the clutch. should i go to the stealership?? what should i replace? clutch, pp, clutch master cylinder? or will they know when then test drive it? thanks again.
jrhcivak
17
Apr 11, 2012 03:55 PM
GoT_EM1
Jan 31, 2008 10:51 AM
toukna
Aug 27, 2004 08:31 PM
Blindstuff
Aug 14, 2003 11:53 AM
blkbeast
May 4, 2003 10:49 AM
