WIRING???????
Old Mar 1, 2003 | 11:44 PM
CRVTEC96's Avatar
Default WIRING???????
Ok i have a problem. I have a CRVTEC. THe head is off a B16 and my problem is my VTEC cuts in and out. Usually if VTEC doesnt Work, I should recieve a code correct?! I have a Vtec Controller and i know its not the wiring from that cuz the Vtec has been acting up since before i got the VAFC, Does anybody body have a clue???????? I also switched ECU with my friend and it worked fine for a night and then it cut out again......please help!
Old Mar 2, 2003 | 05:12 AM
Ryu's Avatar
Ryu
Default Re: WIRING??????? (CRVTEC96)
what ecu you using? OBD2? and what are you setting your vtec engagement at on your vtec controller?
Old Mar 3, 2003 | 02:50 AM
CRVTEC96's Avatar
Default Re: WIRING??????? (Ryu)
im using a 96GSR OBDll, I have the Vtec set at 4600......I know im getting a signal to the VTEC SOL. but im not sure where else to check for current!?
hkrichard
12
Oct 19, 2013 10:07 AM
crx18c1
18
Apr 12, 2007 12:25 PM
nitrousfedef9
11
Oct 5, 2005 09:13 AM
b19coupe
Sep 3, 2003 07:02 PM
IN2VTEC
Jul 20, 2002 12:35 PM
