Assembly of the bottom end?
Old Mar 2, 2003 | 06:12 PM
J2turbo21's Avatar
Default Assembly of the bottom end?
Is it simple that a regular joe and assemble it,or can any local machine shop do it for you?I was gonna have someone do it for me but my motor is sleeved already and all i need is to have it everything balanced,swap in the high comp pistons and bore/hone it to 84.5mm.Im not sure if it should be blue printed or not.Thanks.
Old Mar 2, 2003 | 07:35 PM
joe_bocc's Avatar
Default Re: Assembly of the bottom end? (J2turbo21)
well i don't think that many regular joes can balance their internal or hone their cylinder walls or do a complete blue printing. As for final assembly, it depends if you have all the right tool and the right knowledge. if you are going to do it yourself you'll need a very good and detailed manual of some sort and some experience. well that what i think.
Old Mar 2, 2003 | 07:38 PM
baonest1's Avatar
Default Re: Assembly of the bottom end? (joe_bocc)
well if you have your block.. and also if your pistons already have rods on them and rings... then its easy to install.. but i dont know bout the balancing and all
Old Mar 2, 2003 | 09:04 PM
1 2 NV's Avatar
as far as assembly do it urself. i never touched a block b4 i did mine and **** results speak for themselves. have a machine shop hone it to proper specs and balance the bottom end. then u get the fun of assembly, its easy, takes a couple hrs and u get the accomplishment of doin it urself.
Old Mar 2, 2003 | 10:28 PM
J2turbo21's Avatar
Default Re: Assembly of the bottom end? (hondaatwsu)
So what kind of specs do i tell the machine shop?Also do all machine shops balance and blueprint?
Old Mar 3, 2003 | 05:04 AM
1 2 NV's Avatar
the machine shop should know about specs already. they need the pistons so they can final hone the cylinder to within specs (wall to piston). as far as balancing i gave my machinist everything. that means pistons, rings, rods, wrist pins, lock rings, flywheel, clutch, pulley.
Old Mar 7, 2003 | 09:40 PM
J2turbo21's Avatar
Bump.
Old Mar 10, 2003 | 12:45 AM
J2turbo21's Avatar
What kind of tools will i need and what do i have to replace as far as bearings,gaskets that sort of thing?
Old Mar 10, 2003 | 04:28 AM
speedymon's Avatar
I was wondering this myself. I guess as long as you get the rods pressed onto the pins and all its just simple assembly. I'm trying to avoid $800-900 worth of labor.
Old Mar 19, 2003 | 11:53 PM
J2turbo21's Avatar
Anyone?
Old Mar 20, 2003 | 05:58 AM
94CivicSi's Avatar
replace all gaskets. Everything. You can get complete head and block gasket sets.
Tools: You need a good tourqe wrench. A set of feeler gauges. Ring expander and compressor. A few select metric taps and dies. A dial indicator wouldn't hurt, neither would a set of calipers or a micrometer. Most important, a shop manual. If you don't have the factory specs, it's not going to work properly.
Ryhaz
10
Jan 14, 2014 07:57 AM
nandito
Nov 7, 2011 06:11 PM
jeremy
Oct 20, 2009 05:18 PM
ge_itr
Jan 20, 2007 12:30 PM
Crate
Dec 5, 2003 03:34 PM
