advanced timing MPG question (Just did it)
Old Mar 2, 2003 | 05:36 PM
SSBP DC2's Avatar
Default advanced timing MPG question (Just did it)
i advanced the timing yesterday to a little over 17 deg BTDC. I've read that with the timing advanced you're suppose to run a little leaner. However I felt as though i'm running rich because i filled the tank up to full yesterday and today it's at the 1/2 mark. I didn't drive anywhere far...probably drove it for about 2 hrs total at moderate speed with occasional sprints to see its effect on the power band.
Q: How did your MPG do after timing advance?
TIA for the help
-demitri
Old Mar 2, 2003 | 06:18 PM
the DR.'s Avatar
Default Re: advanced timing MPG question (SSPB DC2)
That's weird... because 17btdc is ~ factory timing, I've set mine to various points higher than that before ~20+ and didnt have a significant MPG decrease, I'd say only in the neighborhood of a couple of MPG at the most..
And how are you managing fuel mixture?
Old Mar 2, 2003 | 06:59 PM
SSBP DC2's Avatar
Default Re: advanced timing MPG question (SlicedBread)
fuel mixture is stock. the factory timing on 94+ GSR's is 14 deg btdc. anyone else?
Old Mar 2, 2003 | 07:46 PM
Lord Helmet's Avatar
Are you talking about ignition timing advances or are you talking about cam timing advances. there's a big difference between the too. when I advanced my cam timing to 2 degrees I also readjusted my ignition timing to compensate the cam timing. fuel milege wise I did notice my car was getting better milege since it was leaning out the air/fuel ratio. it also gave me a little bit more noticeable lower end torque since d16s are not known for torque anyways. I wouldn't go more then 2 degrees advanced due to lack of fuel(and detenotion) which can be compensated by upgrading your fuel system.
[Modified by sleeperciv, 8:47 PM 3/2/2003]
Old Mar 2, 2003 | 10:47 PM
SSBP DC2's Avatar
Default Re: advanced timing MPG question (sleeperciv)
i was talkin about ignition timing bro, sorry for not clearing that up
a1320honda
Engine Management and Tuning
May 9, 2013 11:28 AM
aron0903
Aug 4, 2004 12:34 AM
OneFastLS
May 25, 2002 03:12 PM
