Blown head gasket?
Old Mar 2, 2003 | 03:32 PM
jkthrasher's Avatar
Default Blown head gasket?
I just got an 87 Accord 2bbl 5 speed. The girl said it ran fine then just started smoking badlywhile driving it. It had overheated on her a couple of times before that. It has been parked on a steep slope for 2 years now. I'm pretty sure it's a bad head gasket(or crack) but wanted to get opinions from people that know Honda's better than me; I am a Toyota mechanic. It smokes so bad from the exhaust i can't see the car. It doesn't appear to be getting exhaust in the radiator, the spark plugs are totally dry, and it runs smoothe. It is white smoke (or steam) from the exhaust and a white oil residue also in the exhaust pipe. Are these heads prone to crack at the exhaust ports? just curious what to expect. thanks in advance-
Old Mar 2, 2003 | 04:45 PM
Doogie Howser's Avatar
Default Re: Blown head gasket? (jkthrasher)
check for coolant in the oil (light colored resdue on bottom of dip stick), also look for bubbles in the coolant overflow
Old Mar 2, 2003 | 05:24 PM
delslow94's Avatar
Default Re: Blown head gasket? (Doogie Howser)
you can also check the underside of the oil cap for a white residue to show that the head gasket is blown
Old Mar 2, 2003 | 06:16 PM
jkthrasher's Avatar
There is no coolant in the oil or bubbles in the radiator. Other than the white smoke there are no other blown head gasket symptoms. it's kind of strange; not what i normally see with a bad gasket. There isn't a coolant port in the intake manifold on the carb model, is there? i don't know this car very well.
Old Mar 3, 2003 | 05:58 AM
fathergoose's Avatar
Do a compression test...
Shaaks69
10
Jul 21, 2014 02:52 AM
MikesBB4
Apr 9, 2012 10:17 PM
MikesBB4
Apr 9, 2012 08:47 PM
highrollers23
Sep 2, 2009 06:54 PM
CiViC I2aCeI2
Jan 20, 2006 06:49 PM
