b18a1 vs. b18b
Old Mar 3, 2003 | 05:25 PM
drumking15's Avatar
Default b18a1 vs. b18b
Alright, i know the b18b from the newer generation tegs is a good canidate for a ls/vtec turbo, but at the moment i have the oppurtunity to pick up a b18a1 block from an older teg 90-93 to be exact for really cheap. This motor has been semi rebuilt w/ new thrust and crank bearings, and rod bearings. It also has been checked over by a machine shop to meet the specs and cleaned up...Would this be a bad investment towards my ls/vtec turbo setup. What i really want to know is what are the major changes in the b18b shortblock and the b18a1 shortblock if there are any?
Old Mar 3, 2003 | 05:37 PM
hybridb18's Avatar
Default Re: b18a1 vs. b18b (drumking15)
the b18b1 and b18a1 have the exact same shortblock, no differences. the newer 96 plus b18b1 have different pcv system though
Old Mar 3, 2003 | 05:44 PM
drumking15's Avatar
Default Re: b18a1 vs. b18b (hybridb18)
so if i was to slap a b18c1 head on top i wouldnt run into any ohter problems besides the standard ls/vtec shiznit..correct? The head by the way is from a 94 gsr if that matters at all about the whole pcv system.
[Modified by drumking15, 2:44 AM 3/4/2003]
Old Mar 3, 2003 | 08:09 PM
2000blackgsr's Avatar
set up the same as ls/vtec with a b18b
Old Mar 4, 2003 | 07:18 PM
Quick 200k Mile Motor's Avatar
the only significant difference is the B18B has Knock Sensor
B18A doesnt have it
uses0ap
Mar 30, 2009 09:31 AM
Blacklabel182
Mar 12, 2008 06:44 PM
Malakai
Jul 27, 2006 09:06 AM
makavali27
Dec 4, 2004 11:52 AM
RACING INTEGRATION
Sep 2, 2004 05:40 AM
