H23 in 96 teg (will wiring and computer be OK)?????????
Will I need to adapt the wiring harness other than probably lengthening the alternator wire. and can I still use the LS ECU?
use the teg wire harness, you'll need to extand the sensors and running wires for the egr valve and the secondery runners real easy to do. ls ecu wont work right h23 has a huge fuel curve. i have the h23 ecu $50 shiped and insured. let me know if you have any quetions i can help you with. peace
