Wiring Fog Lights
Old Mar 3, 2003 | 11:06 AM
Ponch's Avatar
Default Wiring Fog Lights
Not sure if this is the right forum for this so i apologize if it's not. I have some after market fog lights that did not come with a relay. i want to install the relay but i'm not sure where it goes. The wiring harness that came with the lights (PILOT) doesn't look like i can throw a relay in there somewhere. Do the lights and power wire get connected to the relay and then the ground and switch? i have no clue. this is going on a 97 Honda Civic HX.
Old Mar 3, 2003 | 11:56 AM
integra6650's Avatar
Default Re: Wiring Fog Lights (Ponch)
i would say ground is direct to the ground and the relay is in the middle of the fogs and the power source (just tap into the headlight power wire) will only turn on with car
Old Mar 3, 2003 | 12:10 PM
Diamante's Avatar
Default Re: Wiring Fog Lights (integra6650)
i really want to avoid wiring them to the headlights. i only want to use them when i really need them. (Fog) i know the style is to have them on whenever the headlights are on but i really just wanna use them when needed. i prefer to control them with a seperate switch.
Old Mar 3, 2003 | 12:19 PM
Raven 69's Avatar
Default Re: Wiring Fog Lights (Diamante)
i skipped the relay. works fine for me. i have heard that a relay is supoosedly good for it but i don't know.
Old Mar 4, 2003 | 08:42 AM
4getu's Avatar
Default Re: Wiring Fog Lights (Raven 69)
Hook up the lights to the relay. Then hook the power wire that has the fuse in it from the relay to your power source (battery). From the relay, you'll wire the wires for the on/off switch. Some relays have a ground pin, USE IT!! If your switch has a ground switch, USE it, if it doesnt but the wiring harness that came with the lights has one, skip it. it won't hurt. besiddes theres nothing for you to ground if the switch doesn't have the pin.
Old Mar 5, 2003 | 06:59 PM
Rukusmasta2's Avatar
Default Re: Wiring Fog Lights (4getu)
what all do you ahve to do to hook them up straight to the headlight so when u turn the car on there on
Old Mar 5, 2003 | 07:04 PM
Default Re: Wiring Fog Lights (Rukusmasta2)
is that a question?
Old Mar 6, 2003 | 10:20 AM
yea its a question
Old Mar 7, 2003 | 05:16 AM
4getu's Avatar
Not sure on that one. i don't get it either. iot's easy to do but i don't know how it's done. come on guys, someone's gotta know how to do this.
henryasdf
Honda Civic (2001 - 2005)
May 31, 2011 04:12 PM
tyronne1126
Lighting
18
Jul 12, 2009 02:40 PM
pjr710
Aug 24, 2007 05:45 PM
oranginal
May 21, 2006 07:31 PM
Optiks.
Sep 30, 2003 07:25 AM
