Tip on pre-ignition - dohc experience.
Old Mar 4, 2003 | 06:47 AM
sbourg's Avatar
Default Tip on pre-ignition - dohc experience.
Drove for a couple of years with a progressively worse problem with pre-ignition on hills and running hot, '88 Integra with > 100k miles. During a routine maintenance I happened to have the upper timing belt cover off with the engine running, and noted a lot of belt vibration between the cam sprockets. This was a puzzle, since the belt and tensioner had been replaced about 20k earlier at the dealer. I went thru the factory procedure to adjust the belt and inspected every inch for problems - none. This completely stopped the vibration, my preignition and overheating vanished, and idle smoothed out completely. It stayed fine until the car was rear ended years later at 186k. Apparently belt tension was not adjusted correctly at the dealer.
Note I don't think the small valve timing oscillations were an issue - ignition timing was, since the distributor is cam-driven. Although this might have shown up if scoped, it did not with a timing light - the variations were cyclic and regular, so the pointer would remain steady when checked at a constant engine speed.
Moral may be to always do the work yourself, or check after others do, if you can.
Steve
Old Mar 4, 2003 | 08:05 AM
joe_bocc's Avatar
Default Re: Tip on pre-ignition - dohc experience. (sbourg)
wouldn't driving around with pre-ignition melt a hole right through the middle of the piston?
Old Mar 4, 2003 | 08:14 AM
sbourg's Avatar
Default Re: Tip on pre-ignition - dohc experience. (joe_bocc)
'Silent' preignition can, as can ignored heavy audible event. However, I simply adjusted my driving style to avoid the audible stuff... and was lucky too. Note that it was only under high load conditions I noted the problem, and timing variance was only probably a couple of degrees. Engine normally aspirated and stock, etc, no mods to aggravate the situation.
Steve
Old Mar 4, 2003 | 10:58 AM
martini's Avatar
Sounds like you are getting some slight detonation, not pre-ignition..
Old Mar 4, 2003 | 11:26 AM
tilt's Avatar
what does pre-ignition sound/feel like?
Old Mar 4, 2003 | 11:56 AM
martini's Avatar
Default Re: Tip on pre-ignition - dohc experience. (tilt)
pre-ignition sounds just like detonation.
Old Mar 4, 2003 | 12:04 PM
sbourg's Avatar
Preignition (or detonation) cause a 'rattling' or 'pinging' sound that gets worse as load or heat increase. Modern lean-burn engines operate normally just shy of this condition, so it doesn't take much to push them over the edge - too low octane fuel, high combustion temperatures, vacuum leaks or malfunctioning EGR, etc. Some vehicles have 'knock' sensors that alter the ignition advance if it is detected.
Steve
Old Mar 4, 2003 | 12:38 PM
tilt's Avatar
hmm, Ive noticed that my car tends to tick more (louder) during idle after ive driven it hard (up to redline). I am going to do a valve adjustment, hopefully that will fix it. Would you say pre-detonation sounds like valve tapping?
Old Mar 4, 2003 | 02:49 PM
martini's Avatar
Pre-ignition and detonation are two seperate things. And I don't know what the heck pre-detonation is.
But no, it doesn't sound like valve tap. It's much louder. like someone dropped a BB in your intake almost. It's not very likely that you are detonating at idle. Usually it only comes when pushing the car hard (lugging up hills, on the dyno without proper cooling, drag racing, etc..)
Old Mar 4, 2003 | 02:55 PM
tilt's Avatar
Default Re: Tip on pre-ignition - dohc experience. (martini)
oops i meant pre-ignition
h22mark
Apr 25, 2007 07:44 AM
just4747
Oct 13, 2004 10:13 AM
batman_22
Oct 30, 2002 03:41 AM
superR303
Apr 28, 2002 05:57 AM
Bert1
Nov 23, 2001 01:20 PM
