abs swap to 99 si
Old Apr 24, 2003 | 09:37 AM
baphomet's Avatar
Modified by b3435 at 9:14 PM 6/14/2003
Old May 8, 2003 | 09:27 AM
RHD_BB4T's Avatar
Default Re: abs swap to 99 si (b3435)
If your car doesn't have ABS, it would be a bitch to add it. I know this, 'cause I'm in the process of trying to REMOVE mine in my Prelude. All the break lines are the factory hard-lines, and these are customized to fit the prelude. I've found that I'm going to have to run aftermarket steel braided brake lines to the master cylinder and to each of the breaks to replace these. And yes, there is a ABS control module (the size of your ECU) that goes along with the ABS itself. Another problem will be your axels themselves. They have ABS rings on the hub side of the axel that you'll need (I've seen people take these off ABS axels and mount them on non-ABS ones though; more work!) and sensors that monitor them.
If you ask me, it'll be an ***-lode of work to ADD it. Anyway, ABS doesn't make you a better driver. Learn to break closer the the lock-up threshold without locking them up, and that WILL make you a better driver because of it.
HTH
Dan P.
Ej8_KiD
Mar 14, 2011 10:43 PM
scoobyghost
Aug 30, 2004 06:15 PM
95swappedsi
Mar 28, 2004 04:40 PM
cpforyou
Jul 27, 2003 03:03 AM
NonovUrbizniz
Apr 15, 2003 09:12 AM
