Radiator swap.
Old Apr 23, 2003 | 03:38 PM
AVATAR's Avatar
Default Radiator swap.
I'm ditching the stock single core civic radiator in favor of the larger dual core intergra radiator. Is there any modification that needs to be done to the car or the radiator? Does the new radiator require a integra radiator hose (or are the ones on my civic the same?) Thanks
Old Apr 23, 2003 | 04:42 PM
integra6650's Avatar
Default Re: Radiator swap. (AVATAR)
integra hoses are needed yes as far as mods to the car not too dificult
hammer old brackets out with cold chissel
make 2 brackets 2x8 or so (home depot aluminum strip)
drill 2 holes one big enough for a 10mm bolt and one at the other end big enough for stand on radiator
on top part take integras brackets flip them upside down
if you need closer pics ill get em
youll have to tap 10 mm holes in the top
took me less than an hour
Default Re: Radiator swap. (integra6650)
where you live maybe i can help
Old Apr 23, 2003 | 04:53 PM
AVATAR's Avatar
Thanks for the awesome details man, unfortunatly I live in the not-so-great state of Texas. Anyways are those modifications necessary if the new radiator is going into a 2000 Si? Thanks again!
Old Apr 23, 2003 | 05:07 PM
Audi RS4's Avatar
Lover
here are just some graphics to show the difference......
integra.....
civic........
Old Apr 23, 2003 | 05:35 PM
AVATAR's Avatar
Default Re: Radiator swap. (AK1200)
hmmm *wonders what #18 on the Integra is and what #s 13 and 14 are*
Thanks for the picture though thats nice and detailed
Old Apr 23, 2003 | 05:43 PM
o ya and i had to cut the 2 rubber pieces on the bottom also i cut right at the rib to make it like a rubber washer
Old Apr 23, 2003 | 06:32 PM
flat-blk-HB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVATAR &raquo;</TD></TR><TR><TD CLASS="quote">hmmm *wonders what #18 on the Integra is and what #s 13 and 14 are*
Thanks for the picture though thats nice and detailed </TD></TR></TABLE>
I think 18 is for a automatic..cooling hose.
13 and 14 are just hose brackets for the lower hose. Most of the time that are on mounted to the tranny..Just to hold it in place..I dont have mine.
Old Apr 27, 2003 | 07:37 PM
vtecdc2's Avatar
Default Re: Radiator swap. (flat-blk-HB)
hmm.. im intrested too.. i need a new radiator, and the integra radiator would be cool. any major improvements?
Old Jul 6, 2003 | 10:31 PM
mor ber's Avatar
Default Radiator design
Yes! I too am wondering what these are. These small hoses are not connected to the main system, do they take up a lot of core space? Are they for an automatic trans?
Old Jul 6, 2003 | 10:57 PM
salbaje's Avatar
why not just use a dual core del sol dohc radiator??
Old Jul 7, 2003 | 03:08 PM
Default Re: Radiator swap. (salbaje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salbaje &raquo;</TD></TR><TR><TD CLASS="quote">why not just use a dual core del sol dohc radiator??</TD></TR></TABLE>
Because that would be like a single core Integra..If you get a dual core integra then you got 4 times the cooling fins as a stock single core civic.....I think
tolowhb
Jul 9, 2003 02:22 PM
