does cam gears has to be set at 0 to do valve adjustment?
Old Aug 21, 2003 | 10:49 AM
91integraLSVTEC's Avatar
Default does cam gears has to be set at 0 to do valve adjustment?
my head is milled .030 and the block has been deck, both of my cam gears is advanced.. my machine shop guy said cam timing has nothing to do with setting the valve lash.. is that tru?? tia
Old Aug 22, 2003 | 06:59 PM
Default Re: does cam gears has to be set at 0 to do valve adjustment? (91integraLSVTEC)
all these tech gurus and cant answer this question.. thanks..
Old Aug 22, 2003 | 08:54 PM
Runnerdown's Avatar
Absolutely true, setting the valve lash has nothing to do with cam gear settings. As long as the cams base circle is level with the rocker you can do the adjustment. Ignore the fact that I am a nOOb on this forum.
Gump
Sep 20, 2004 03:09 PM
Austin
Nov 18, 2002 01:20 PM
Comptech98GSR
Aug 2, 2002 12:28 AM
Comptech98GSR
Aug 1, 2002 02:28 PM
94GSRNewbie
Jul 26, 2001 11:06 PM
