Need some B series Bore sizes
Old Aug 22, 2003 | 06:13 PM
flat-blk-HB's Avatar
Default Need some B series Bore sizes
Ok I have a 99 LS block and am trying to put some year (not sure) type R pistons (integra) in it. Well it is my friend who is doing this. Well what is the differnece in the bore?
The R's wont fit and are off by like a hair pin. Then trying the LS pistons they well slide in correctly... Is there a diff in the bore?
Old Aug 22, 2003 | 06:30 PM
TREVER's Avatar
Default Re: Need some B series Bore sizes (flat-blk-HB)
there both 81mm time to invest in some measuring tools
Old Aug 22, 2003 | 07:36 PM
Default Re: Need some B series Bore sizes (TREVER)
ALright then I will let him know.
Old Aug 22, 2003 | 08:22 PM
slowtealgsx's Avatar
i believe all b series are 81.5mm
Old Aug 22, 2003 | 08:31 PM
Aceman64's Avatar
Default Re: Need some B series Bore sizes (slowtealgsx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowtealgsx &raquo;</TD></TR><TR><TD CLASS="quote">i believe all b series are 81.5mm </TD></TR></TABLE>
Almost....B20
-Ace
Old Aug 23, 2003 | 04:30 AM
non-VTEC's Avatar
ALL b-series engines are 81mm stock bores with the exception of the B20 which is 84mm.
Old Aug 23, 2003 | 05:36 AM
T4eg's Avatar
Default Re: Need some B series Bore sizes (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">ALL b-series engines are 81mm stock bores with the exception of the B20 which is 84mm.</TD></TR></TABLE>
Old Aug 23, 2003 | 09:13 AM
ghettochild7's Avatar
Default Re: Need some B series Bore sizes (BlueHatch00)
yeah he's right all b series are 81mm
Old Aug 23, 2003 | 10:52 AM
MikelH's Avatar
He might have some .25 overbore P73 pistons.
You could always bore out the cylinders to get rid of any imperfections and then put them in.
Old Aug 23, 2003 | 06:40 PM
Default Re: (MikelH)
I think he is going to just put his B16's back in there....
Old Aug 23, 2003 | 09:55 PM
TeStUdO's Avatar
all b series are 81 except B20 is 84 like stated earlier. measure your piston sleeves
Old Aug 24, 2003 | 09:41 AM
Spoond TEG's Avatar
Default Re: Need some B series Bore sizes (TeStUdO)
Look on the top of the Type R pistons and if there is a number 25 written on them then you have over bore pistons.
All b series are 81mm except the b20 and all pistons come in over bore size up to .25mm over.
If the pistons are used then it might be harder if not impossible to see the 25. Other than that measure the thing
crvtkllr
Nov 26, 2009 10:30 AM
tunerboy90
May 20, 2008 10:30 AM
haroldthefly91crx
Sep 1, 2007 02:37 PM
cbp_crx
Nov 12, 2006 10:17 AM
b16a27
Mar 31, 2005 10:28 AM
