ignition coil problems
Take off the distributor cap, static shield, and rotor. You can test the resistance of the primary and secondary connections with an ohmmeter. Ensure that it is within spec according to your vehicle-specific Haynes/Helms.
To answer you questions, yes, a bad coil can cause intermittent firing, and sputtering.
i have the msd sci ignition, i currently have the blaster ss coil, i was going to go with the blaster three coil, i know this is a bit of a down grade but the price is great, will it work well with the sci ignition?
loki2323
Sep 3, 2005 11:44 AM
