Valve cover nut stripped
Old Aug 23, 2003 | 11:54 AM
Beave0101's Avatar
Default Valve cover nut stripped
I've delt with broken studs. I'm not sure if it's the stud or the bolt this time:
I'd removed the valvecover a dozen times in the last few weeks, did alot of work on the head, and than swapped to a friend's valvecover which is cut, much easier for tuning.
today i wanted to switch back to MY v/c, and the bottom left nut just turns. not loose, not tight, it just turns
and advice, other than cutting the nut and the stud and replacing both ?
Old Aug 23, 2003 | 06:44 PM
Beave0101's Avatar
Default Re: Valve cover nut stripped (Beave0101)
Old Aug 23, 2003 | 07:03 PM
hondapwr's Avatar
Are you talking about that little chrome nut on your average B series valve cover? I'd just order a new stud and nut. The stud is really easy to remove with a wrench. DO NOT OVERTORQUE THE NUTS!
Old Aug 23, 2003 | 07:27 PM
Beave0101's Avatar
Default Re: Valve cover nut stripped (hondapwr)
well I know I need a new stud, and trust me, replacing it is the first thing I will do....
........after I can find a way to get it off
Old Aug 24, 2003 | 07:06 AM
Daemione's Avatar
Only way I could get it off was to dremel off the entire top . . . .
You'll need a deep 10mm socket to remove the old stud & install the new.
Old Aug 24, 2003 | 08:14 AM
blah13's Avatar
Default Re: Valve cover nut stripped (Daemione)
I used a deep impact socket to get mine out, no cutting needed. Its simple.
Old Aug 24, 2003 | 12:08 PM
2000fbp's Avatar
Default Re: Valve cover nut stripped (blah13)
Take off your val;ve cover and get a deep socket 10mm wrench or imapact wrench, take it off and put on the new ones. I ordered mine (cap and stud) from http://www.hondaautomtiveparts.com. If You have the extra cash just by yourself some back ups too if you remove your valve cover that often.
Old Aug 24, 2003 | 12:16 PM
LudeyKrus's Avatar
if it's stripped, try loosening all the other nuts and jerkin up on the valve cover, while turning the nut. if not, I'd say take a dremel w/ a cutting wheel and grind off the nut flat.
ryanangelo212
Oct 27, 2010 08:02 PM
Jdmglenn
May 5, 2005 09:40 AM
rayscar
Oct 11, 2004 10:34 AM
Hybrid 350GT
Aug 29, 2004 01:20 PM
Phoenix_ITR
Dec 25, 2002 09:46 PM
