engine light comming on
Old Aug 22, 2003 | 06:14 PM
Turbo12acer's Avatar
Default engine light comming on
I have a 86 civic SI HB. the engine light on the car says PGM-FI and it turns on when i go on a 30min trip but when i turn off car. it goes away and comes back on later when i drive more. Anyone know what is the problem? The car runs great with 232k miles! Im also trying to find the connection for the computer so i can connect the diagnostics to see whats wrong. thanks in advance
Old Aug 22, 2003 | 09:19 PM
HONDADNA's Avatar
Default Re: engine light comming on (Turbo12acer)
Your Civic does not have the Service Check Connector. but under the seat or under the passenger side carpet in where the ecu should be. You have to read the blinking LED light from the ecu to know what the code is.
Old Aug 23, 2003 | 12:41 PM
OK, i found the ecu under the passenger seat. Do i check the lights when the engine lights come on and car is still running? Because if i turn off the car and turn ignition the engine light is gone.. thanks
Old Aug 23, 2003 | 12:46 PM
Chiovnidca's Avatar
Default Re: (Turbo12acer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo12acer &raquo;</TD></TR><TR><TD CLASS="quote">OK, i found the ecu under the passenger seat. Do i check the lights when the engine lights come on and car is still running? Because if i turn off the car and turn ignition the engine light is gone.. thanks</TD></TR></TABLE>
Just turn the ignition on and check the code/s. It should have it stored in memory.
Old Aug 25, 2003 | 06:08 AM
i just looked and there are no blinking led lights. there is just 1 led lit. no codes?
SolidSpruce
Jul 8, 2023 03:19 PM
kuks24
Jun 3, 2008 05:33 PM
97_dc2
Apr 13, 2007 07:36 AM
sublimenerd
Oct 19, 2006 09:11 PM
jdm82
Mar 7, 2006 01:08 PM
