ARP head stud question...?
Old Aug 24, 2003 | 12:53 PM
clsmooth's Avatar
Default ARP head stud question...?
Do ARP head studs required to be installed by a machine shop? Particularly, to thread in the studs into the block?
I've tried doing it by hand, like the instruction say, but haven't had very much luck.
Old Aug 24, 2003 | 02:28 PM
AzG35's Avatar
Default Re: ARP head stud question...? (clsmooth)
You should be able to do them by hand. Are you sure you're putting them in right side up? They will only thread in 1 way.
Old Aug 24, 2003 | 05:44 PM
Nameless RB26's Avatar
Default Re: ARP head stud question...? (AzSi22)
You can't do it by hand usually. You use two of the nuts on top of each other and tighten it down.
Old Aug 24, 2003 | 05:48 PM
IN VTEC's Avatar
The thread pitch on both ends are different. The block side is 1.5 and the head side is 1.25.
Make sure you don't have them in upside-down.
Old Aug 24, 2003 | 06:47 PM
real9999's Avatar
Default Re: ARP head stud question...? (IN VTEC)
If the threads are clean, and you lube up the studs before putting them in, they should go in with little resistance.
Tom
clsmooth's Avatar
I would thread it in by hand, but with the aid of vice-grips or 'double-nutting' the stud. I do this til the stud 'bottoms-out' in the block. This causes the stud to not protude enough into the head to get the nut on.
If the stud is not 'bottomed-out', then the nut ends up pulling up the stud out of the block, when attempting to tighten down the nut.
I'm installing this into my ZC, and bought ARP studs intended for a D16Z. The over-all lenght of the stud is the same as the factory head bolt.
dfJDM
16
Oct 22, 2012 12:28 PM
DC2-ProdUcTiOnS
Oct 27, 2011 02:07 PM
GSR_hatch936
May 27, 2008 06:09 PM
CTR-CRX
Mar 14, 2004 07:05 PM
trbob16a
Apr 23, 2003 04:54 AM
