HELP!! What is a fuel pressure damper?
Old Aug 21, 2003 | 05:58 AM
d15b7racer's Avatar
Default HELP!! What is a fuel pressure damper?
The only reason i ask is because i'm running an MSD inline fuel pump on my turbo setup and wanted to change my fuel lines to stainless steel so i was checking out the Russell Performance sites and i think i have to just buy the banjo fittings and custom the lines. Heres the site and i'm thinking i have to either buy part number 640910 or 640920 but i dont know if my 1994 Civic DX (d15b7) has a fuel pressure damper or not. I dont even know what a fuel pressure damper is. Please help! thanks
Old Aug 21, 2003 | 07:34 AM
WundedSaint's Avatar
Default Re: HELP!! What is a fuel pressure damper? (d15b7racer)
a fuel pressure dampener eliminates the fluctuation of fuel pressures when the injectors are opening and closing, without one the injectors won't spray the correct amount of fuel perfectly. A fuel pressure regulator controls fuel pressure depending upon the engine load (through manifold vaccuum). I suggest getting one with a fuel pressure damper since you're modifying your fuel system which is a mpfi (multiport fuel injection) type system.
rmc
Igaly
Honda Civic (2001 - 2005)
Apr 16, 2009 03:17 PM
jman86
Aug 26, 2006 08:13 AM
Islander
May 19, 2003 11:08 AM
toooslow
May 15, 2003 12:21 PM
Bantam
Mar 7, 2003 08:58 AM
