Flywheel bearing
Old Aug 24, 2003 | 12:42 PM
Vtec-Jesus's Avatar
Default Flywheel bearing
im installing my clutch and flywheel and when i opened the flywheel box i noticed the bearing was not in the flywheel but on the alignment tool. do i just use like a rubber mallet to hit it in place or is there some way i have to get it in
thanx.
Old Aug 24, 2003 | 02:45 PM
Lord Helmet's Avatar
Default Re: Flywheel bearing (Vtec-Jesus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec-Jesus &raquo;</TD></TR><TR><TD CLASS="quote">im installing my clutch and flywheel and when i opened the flywheel box i noticed the bearing was not in the flywheel but on the alignment tool. do i just use like a rubber mallet to hit it in place or is there some way i have to get it in
thanx.</TD></TR></TABLE>
they actually do have a special tool to get the flywheel bearing perfectly straight BUT you can get away with the rubber mallet. that's what I did when I didn't have the special tool. just make sure it's perfectly straight and align with the flywheel surfaces.
Old Aug 24, 2003 | 02:59 PM
Se-rv-Tak's Avatar
Default Re: Flywheel bearing (sleeperciv)
ya, you can just use a rubber malletm, no point in spending money that could be used elsewhere. You could use that money to get your clutch/brake fluid for your car.
Or a towtruck if u did mess up on your flywheel installation... hahaha jk.
Old Aug 25, 2003 | 05:36 PM
Vtec-Jesus's Avatar
hmm its not wanting to go in is there some kinda grease i could use to help it slide in
Old Aug 25, 2003 | 09:32 PM
4DeepCivic's Avatar
Default Re: (Vtec-Jesus)
I used a little grease and used and old valve to pop it in flat and straight.
Old Aug 26, 2003 | 07:55 AM
T4eg's Avatar
Default Re: (4DeepCivic)
its called a pilot bearing. Just tap it out from the back with a drift and hammer. And make sure it seats all the way down when you install the new one
Old Aug 26, 2003 | 10:40 AM
raene's Avatar
And remember to tap the outside of the bearing using a large socket; don't smack the inside of the bearing or you'll ruin it before it's ever installed
Old Aug 26, 2003 | 08:23 PM
Se-rv-Tak's Avatar
Default Re: Flywheel bearing (raene)
u know what.... get a new pilot bearing from a part's shop.
the one you have maybe the wrong one for it by accident.
because ti should just go in there with a hammer, or hammer and socket... i used a rubber mallet to get it in there...
and then to make sure it was set i used a socket then the mallet.
and it worked just fine.
Old Aug 26, 2003 | 10:00 PM
R6Boy69's Avatar
Default Re: Flywheel bearing (Soon2B18Boost)
yeah use a socket that is large enough to go around the outer rim so you dont risk damage to the bearing... goes right in with a couple taps.
Old Aug 27, 2003 | 01:35 PM
Se-rv-Tak's Avatar
Default Re: Flywheel bearing (crXBoy69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crXBoy69 &raquo;</TD></TR><TR><TD CLASS="quote">yeah use a socket that is large enough to go around the outer rim so you dont risk damage to the bearing... goes right in with a couple taps.</TD></TR></TABLE>
agreed.
Old Aug 27, 2003 | 01:41 PM
HYBRID_H@TCH's Avatar
I use a hammer and a little block of wood..works great
Old Aug 27, 2003 | 01:42 PM
Se-rv-Tak's Avatar
Default Re: Flywheel bearing (99Hybrid_Hatch)
never heard that, but it will probably work the same.
Nathan007
Transmission & Drivetrain
Jun 19, 2009 06:31 PM
unknown0001
Dec 14, 2006 12:27 PM
skunkwhat
May 15, 2005 09:04 PM
JAYGSR
Oct 5, 2004 05:56 PM
GRAVEDIGGER
Sep 2, 2004 11:57 AM
