h22 rc 550 injector problem
Old Aug 23, 2003 | 08:39 PM
h22 civic's Avatar
Default h22 rc 550 injector problem
its a h22 with aem and external fuel system the car started running weird so i changed plugs wires re gaped so on and so forth but no fix what happens is if i hold the throttle stedy at 2000 rpm it kind of bounces up and down a couple hundred rpm in like a pulsating way and if i go steady at 3000 same thing pulsating but the intervals are a little further in between if i go to 4000 same deal with longer pulsating intervals in between if i put the car in gear and drive it also pulsates it wwill still rev up but it starts popping at higher rpms know i took the plugs out agin and noticed #1 cylinder is running rich #2 cylinder running rich #3 cylinder looks to be running lean not as sooty as the other cylinders and # 4 cylnder is running rich i checked spark and it is all good in every cyl so im thinking my # 3 injector is not working right ,how could i be sure ? any input would help
Old Aug 24, 2003 | 05:11 PM
h22 civic's Avatar
Default Re: h22 rc 550 injector problem (h22 civic)
ok i took the car out to the high way and noticed that as i give the car gas my air fuel meter goes lean immediatly and the car starts poping and has no power but if i give the car gas slowly it will still rev up any input?????????my fuel presure still rises in boost though
Old Aug 24, 2003 | 06:16 PM
thid92's Avatar
can I haz?
are they peak and hold or saturated?
Old Aug 25, 2003 | 01:13 AM
Lost Type R's Avatar
Default Re: (thid92)
did you just slap em on and drive? It would usually just run like **** if you dont lean your car out with a VAFC or something. Talk to your local tuner and setup a dyno session to tune your car.
Old Aug 25, 2003 | 11:54 AM
h22 civic's Avatar
Default Re: (Lost Type R)
they are peak and hold and the cars been dynoed and tuned for over a year and was running great maybe bad gas or filter the car is turbo if that helps thjis pos aem ems dosnt flash a engine code so you got to go through the whole car and find whats wrong
Old Aug 25, 2003 | 02:34 PM
thid92's Avatar
can I haz?
did you just get the injectors or have you had them in the car for a longer time with no problems, kinda explain here i am not sure if you just put them in.
Old Aug 25, 2003 | 03:36 PM
h22 civic's Avatar
the whole car been together for a year
Turbod Fullclip
Apr 22, 2013 01:44 PM
rick7639
Aug 21, 2007 03:46 PM
Felt.2
Jan 20, 2007 10:28 AM
13secondmonster
May 14, 2004 07:23 AM
2trix
May 5, 2003 10:26 PM
