how to do a compression test?
Old Aug 24, 2003 | 12:40 PM
91TegLS's Avatar
Default how to do a compression test?
Ok, I bought the tester, now I'm just wondering exactly how you do the test.
Old Aug 24, 2003 | 01:51 PM
GeeReg's Avatar
Default Re: how to do a compression test? (91TegLS)
http://www.c-speedracing.com/h...t.php
Found via that wonderful thing in the corner....the search button.
Old Aug 24, 2003 | 01:58 PM
91TegLS's Avatar
sorry I'm an extremely ignorant bastard, actually I'm just kinda pissed because I think my engine's about to blow
Old Aug 24, 2003 | 02:53 PM
GeeReg's Avatar
Default Re: (91TegLS)
Well I suppose that's a pretty good reason. What's going on with it?
Old Aug 24, 2003 | 06:36 PM
SDT Project EF's Avatar
Default Re: (GeeReg)
pull the ecu fuse, pull out the spark plugs, put the tester down where the plugs were, and then crank over the motor till the psi stops moving on the gauge
Old Aug 24, 2003 | 09:56 PM
roydogg's Avatar
Default Re: (SDT Project EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SDT Project EF &raquo;</TD></TR><TR><TD CLASS="quote">pull the ecu fuse, pull out the spark plugs, put the tester down where the plugs were, and then crank over the motor till the psi stops moving on the gauge
Can't say it any better .
Old Aug 25, 2003 | 08:10 PM
GeeReg's Avatar
Default Re: (roydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roydogg &raquo;</TD></TR><TR><TD CLASS="quote">
Can't say it any better .</TD></TR></TABLE>
Opening the throttle would help...
Old Aug 25, 2003 | 08:18 PM
mntuner2's Avatar
lol thats funny.
Old Aug 25, 2003 | 09:03 PM
91TegLS's Avatar
So it's the ECU fuse ya pull.. thanks for the help, I pulled a 15 amp fuse in the top right corner of the fuse box by the clutch pedal and it wouldn't crank over, I think that may have been something else though.
Old Aug 27, 2003 | 06:56 PM
mntuner2's Avatar
The ECU fuse is in the engine compartment fuse block. It says ECU on the fuse block cover. I think its 15 amp?? Don't want to quote me on that one though.
Old Aug 28, 2003 | 06:11 AM
T4eg's Avatar
Default Re: (mntuner2)
Give each cylinder you are testing the same amount of cranks. So it will be a fair test
Razr2
Jan 21, 2008 08:24 AM
B18CivicHatch
Aug 24, 2007 12:11 AM
JDM00SI
Aug 26, 2005 05:20 PM
Scean
Aug 23, 2004 06:50 PM
CNSK
Mar 29, 2003 12:45 PM
