Swelling lower Radiator hose.
Hi guys,
I have a strange problem. The lower radiator hose is swelling just after it exits the head.
I did a check in the radiation for co2 gass and it came up clean, and took out the thermostat. No over heating no engine problems.
So what would cause the hose to swell only after the thermostat?
zort
zort
just the inner structure of the hose weakening, the coolant system does have to hold pressure. I would recommend just replacing the hsoe and everyhting should be fine
You see this is the problem this is a new hose purchased from the dealer just a month ago. I changed it because of the same problem.
Any ideas?
zort
Any ideas?
zort
does your car run hot? could be "melting" the hoses.if it is right before it goes into the head (thermostat housing) is sounds like the flow may be restricted causing the bulging of the hose. maybe try doing a coolant flush.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zort_zrt »</TD></TR><TR><TD CLASS="quote">... this is a new hose purchased from the dealer just a month ago. I changed it because of the same problem...</TD></TR></TABLE>Do you have a bad radiator cap? That can put too much pressure in the cooling system.
zx92027xz
19
Jan 15, 2014 04:36 AM
billy hoang
Jan 21, 2007 01:17 PM
