help with code 21 :(
Old May 21, 2004 | 01:52 PM
wickedEFguy's Avatar
Default help with code 21 :(
well last night for the first time I got my car running but I'm throwing a few codes. to start off I have a 90 CRX Si with a 1st gen B16 and a PW0.
So far I'm CEL's 7 (TPS), 4 (map vaccum), and 21 (VTEC solinoid). Ok now my TPS isn't hooked up yet since I broke the one that came with my motor and haven't installed the new one, I don't have all the vaccum lines hooked up either so that explains map, now that leaves 21 but here's the thing I check all the wiring with a voltmeter from the solinoid itself to the ecu pin and it gets connectivity.
I tested the solenoid with giving it some power and it clicks like it's supposed so I figured it's good. I used Katmans diagram for the VTEC wiring if anybody was wondering and yes I did connect it to A17
is there anything else that I'm missing here? I'm thinking I might have a bad ECU but I'm not sure yet
Old May 22, 2004 | 01:43 PM
Kruzen510's Avatar
Default Re: help with code 21 :( (wickedEFguy)
thats a good one. we've been tryin to figure it out too. i was with my buddy a couple weeks ago drivin down the road and his timing belt broke in his gsr. only bent two valves surprisingly. anyways we took the head off took it to the machine shop got it fixed put the head back on the car and fired it up. ran great took it for a ride and the cel came on. pulled a 21 same as yours. he forgot to take the vtec solinoid off when he took it to the shop. we figurured it ruined it when they boiled it or something. so we took my vtec solinoid off my b18c and put on his, reset the computer and went for another drive. pulled the same code. so we dont know what to do now. sorry this doesn't help but would like some info on this also.
Old May 22, 2004 | 03:36 PM
rollinchassis's Avatar
it spouse to be A8 for vtec
Old May 22, 2004 | 03:54 PM
Default Re: help with code 21 :( (rollinchassis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollinchassis &raquo;</TD></TR><TR><TD CLASS="quote">it spouse to be A8 for vtec </TD></TR></TABLE>
oops my bad I typed A17 for some reason instead of A8 but yes I do have it hooked up correctl
anyways if anybody can help out or suggest anything that would be awesome
Old May 23, 2004 | 11:14 PM
bump, somebody has got to know the answer or some advise this is driving me nuts
Atech77
Feb 15, 2010 08:17 PM
sicivic
Nov 28, 2005 07:51 PM
luciffer
May 13, 2005 08:59 AM
DAMCOOLDAV
Sep 28, 2003 11:34 AM
