ECU question for my 92 Integra
Old Jan 31, 2007 | 09:20 PM
Htounndea's Avatar
Default ECU question for my 92 Integra
Alright, this is my situation, im going to be doing a swap into my 92 DA.
My setup as of now is 2000 GSR head, 99 B20Z block, 96 GSR Tranny, everything is OBDII, my question is which ECU would work best for my setup if i am just swapping everything in as is. Also do i have to use something like a p72 obdI, if thats the case, do i have to use some kind of jumper, or can i use a p72 obdII, and in that case what do i have to modify..? Thnx for the feedback...
Old Feb 1, 2007 | 12:26 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: ECU question for my 92 Integra (Htounndea)
Just use the OBD1 P72 ECU it plugs right in. You're gonna have to swap the distributor plugs over from your integra if the distributor you're going to using is OBD2. Also use the injectors from your DA as the OBD2 injector plugs are different. Also are you doing a cable to hydro trans kit?
Seanz_Ac_Da
Feb 26, 2013 06:38 PM
Princequeeley
Mar 16, 2011 10:39 AM
mountaindewguy
Dec 25, 2005 06:24 AM
jaydm ferio
Oct 19, 2004 03:19 PM
